.NET
Active Member
jiallxy
Message 1 of 11 (680 Views)
what happen to the file of AcMgd.dll in my project
680 Views, 10 Replies
12-20-2012 09:58 PM
 Hi ,
Is there somebody can help me?
Everytime, I build my project, there is following warning coming out and asks me to remove the reference file "ACMgd".
Warning 1
 The referenced assembly "AcMgd" could not be resolved because it has a dependency on "System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which is not in the currently targeted framework ".NETFramework,Version=v4.0,Profile=Client". Please remove references to assemblies not in the targeted framework or consider retargeting your project. AutoCADHoodDWG
Best regards,
Jusitn
jiallxy wrote:
 Hi ,
Warning 1
Best regards,
Jusitn
Try retargeting to full .NET 4.0 version instead of Client.
Now than you mentioned this:
<quote>
I use VS 2010 C# to program a stand alone application.
</quote>
Please be aware, the Acad .NET API assemblies (acdbmgd.dll/acmgd.dll...) can only be used inside AutoCAD (if you do Acad addin DLL project). You CANNOT use them with stand-alone EXE project.
jiallxy wrote:
Hi
I use autocad2012 64bit version with win7 64bit os. The C:\ObjectARX 2012 is my folder for ObjectARX.
all of them are reommended by autodesk's website. They shuould work together properly.
Do I understand correctly that you're trying to make external exe-file (not dll-file that will be loaded with NETLOAD command into AutoCAD)? If so, then you can not use acmgd.dll and acdbmgd.dll in your project.
glanard
Message 2 of 11 (671 Views)
Re: what happen to the file of AcMgd.dll in my project
12-20-2012 10:38 PM in reply to: jiallxy
- Do you use the correct release of ObjectArx?
- In VS, did you switch its "Local Copy" property to FALSE?
Valued Contributor
amanero
Message 3 of 11 (659 Views)
12-21-2012 04:32 AM in reply to: jiallxy
I suppose that you are working with Autocad 2013, if I'm correct, review yor project properties, the target .NET Framework for your app mus be 4.0 (probably you have 3.5).
Luis Alberto Manero, Geograma.com
Active Member
jiallxy
Message 4 of 11 (655 Views)
12-21-2012 05:57 AM in reply to: glanard
Hi
Valued Mentor
jeff
Message 5 of 11 (643 Views)
12-21-2012 06:29 AM in reply to: jiallxy
jiallxy wrote:
 Hi ,
Warning 1
Best regards,
Jusitn
You can also find your answers @ TheSwamp
norman.yuan
Message 6 of 11 (632 Views)
12-21-2012 07:48 AM in reply to: jiallxy
<quote>
</quote>
Moderator
Alexander.Rivilis
Message 7 of 11 (632 Views)
12-21-2012 07:54 AM in reply to: jiallxy
jiallxy wrote:
Hi
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Member
jiallxy
Message 8 of 11 (616 Views)
12-21-2012 11:54 AM in reply to: Alexander.Rivilis
Yes, you are right.
I have just found that these two dll files only can be used in add-in projects.
I have to use COM interop: Autodesk.AutoCAD.Interop
The problem is that the COM interop have less good functions and is more difficult to program.
I will try to balance which way I should choose.
thank you very much!
Active Member
jiallxy
Message 9 of 11 (615 Views)
12-21-2012 11:56 AM in reply to: norman.yuan
Yes, you are right.
I have to use COM interop: Autodesk.AutoCAD.Interop for standalone application.
Active Member
jiallxy
Message 10 of 11 (613 Views)
12-21-2012 11:57 AM in reply to: jeff
Thank you!
I changed the framework type, and it works!
