I am using the following to transform coordinates
Public Function TransformPointWCStoUCS(ByVal WCSPnt As Point3d) As Point3d Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim m As Matrix3d = ed.CurrentUserCoordinateSystem.Inverse() Return WCSPnt.TransformBy(m) End Function Public Function TransformPointUCStoWCS(ByVal UCSPnt As Point3d) As Point3d Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim m As Matrix3d = ed.CurrentUserCoordinateSystem Return UCSPnt.TransformBy(m) End Function
The WCS to UCS is returning a negative value for Y. Is there another version of these that I need to be using?
here my code for one function :
'------------------------------------------------------------------------- '------ Conversion d'un point vers le WCS (SCU général)------------------- '------------------------------------------------------------------------- 'Entrée : ' un point 3D ' Debug : si true alors affichage ' 'Sortie : Un point 3D '------------------------------------------------------------------------- Public Function TransformPointToWCS(ByRef point As Point3d, Optional ByVal Debug As Boolean = False) As Point3d Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim ed As Editor = doc.Editor Dim Db As Database = doc.Database Dim ret As Point3d 'conversion vers le WCS (du point uniquement) Dim newMatrix As Matrix3d '= New Matrix3d() Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem Dim cs As CoordinateSystem3d = ucs.CoordinateSystem3d newMatrix = Matrix3d.AlignCoordinateSystem( Point3d.Origin, _ Vector3d.XAxis, _ Vector3d.YAxis, _ Vector3d.ZAxis, _ cs.Origin, _ cs.Xaxis, _ cs.Yaxis, _ cs.Zaxis) ret = point.TransformBy(newMatrix) If Debug = True Then ed.writemessage(vbCrLf & "x : avant " & point.X & " apres : " & ret.X & _ vbCrLf & "y : avant " & point.Y & " apres : " & ret.Y) End If Return ret End Function
You can have a look at the Point3d.Trans() overloaded extension methods in the GemetryExtensions library and/or at a way to P/Invoke the acedTrans() ObjectARX method.
