.NET
Active Contributor
jprisbe
Message 1 of 4 (395 Views)
Wblock crashing in .NET
395 Views, 3 Replies
11-19-2012 10:44 AM
I have a .NET DLL that a gathers object ids of entities grouped within bounding boxes and then WBlocks each group of entities to individual dwg files. I'm getting an pretty consistent crash when transaction.commit gets called. If I comment out the wblock call (sourceDatabase.Wblock(targetDatabase, objectIdColl, dwgBasePoint, DuplicateRecordCloning.Ignore)) I never get the crash.
Anyone seen anything like this before? Any suggestions?
Active Contributor
jprisbe
Message 2 of 4 (391 Views)
Re: Wblock crashing in .NET
11-19-2012 10:52 AM in reply to: jprisbe
I'm also seeing this every now and then.
Active Contributor
jprisbe
Message 3 of 4 (381 Views)
11-19-2012 11:26 AM in reply to: jprisbe
I also see this sometimes as well.
System.InvalidOperationException: Operation is not valid due to the current state of the object.
   at Autodesk.AutoCAD.DatabaseServices.Transaction.CheckTopTransaction()
   at Autodesk.AutoCAD.DatabaseServices.Transaction.DeleteUnmanagedObject()
Valued Mentor
DiningPhilosopher
Message 4 of 4 (345 Views)
11-20-2012 12:33 PM in reply to: jprisbe
This error happens when you use an API that requires an active transaction, with the most-likely culprits being ObjectId.GetObject() or TransactionManager.GetObject()
The problem is in your code, and I suspect the other problem is as well.
If you need help tracking down the source of the errors, you're going to have to show the code where it happens. Otherwise, you will have to run your code in the debugger and it should break on the line when the exception occurs.
