.NET
.NET
Moderator
277 Kudos
Post 11 of 16
Re: Way of getting all objects between two points.
03-12-2013 03:57 PM in reply to: e1028439
e1028439 wrote:
Dear Peter, i modified your code a little bit to use Editor.SelectCrossingWindow, and now it throws a eNotImplementedYet exeption on the following line >vl.IntersectWith()<.
What kind of entity (name of class) was intersected?
I also recommend to use Intersect.OnBothOperands instead of Intersect.ExtendBoth because many kind of entities can not be extended.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Member
0 Kudos
Post 12 of 16
03-12-2013 04:39 PM in reply to: Alexander.Rivilis
it was an InfiniteLine, and i tried all 4 of the possible intersect enum types, all throw the same eNotImplementedYet exception
Valued Mentor
175 Kudos
Post 13 of 16
03-12-2013 08:55 PM in reply to: e1028439
The code you're trying to use doesn't work as posted because it passes null to IntersectWith() in the argument that requires a Point3dCollection.
That may be what is causing the exception.  Create a new Point3dCollection and call it's Clear() method just before each call to IntersectWith().
Valued Mentor
175 Kudos
Post 14 of 16
03-12-2013 08:58 PM in reply to: e1028439
The base AutoCAD product API has no class called "InfiniteLine".
The XLine is an infinite line, so perhaps that's what you meant?
Active Member
0 Kudos
Post 15 of 16
03-12-2013 09:20 PM in reply to: DiningPhilosopher
var doc = Application.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            var db = doc.Database;
            var ppo = new PromptPointOptions("\nSelect point: ") { AllowNone = false };
            var pt1 = ed.GetPoint(ppo).Value;
            var pt2 = ed.GetPoint(ppo).Value;
            var psr = ed.SelectCrossingWindow(pt1, pt2);
            var vl = new Line(pt1, pt2);
            var oic = new ObjectIdCollection();
            if (psr.Status != PromptStatus.OK)
                return;
            using (var dl = doc.LockDocument())
                using (var tr = db.TransactionManager.StartTransaction())
                    Point3dCollection p3dc;
                    foreach (SelectedObject so in psr.Value)
                        p3dc = new Point3dCollection();
                        var ent = tr.GetObject(so.ObjectId, OpenMode.ForRead) as Entity;
                        try
                            vl.IntersectWith(ent, Intersect.OnBothOperands, p3dc, new IntPtr(), new IntPtr());
                            if (ent != null && p3dc.Count > 0)
                                oic.Add(ent.ObjectId);
                        catch (Exception) { }
            ed.WriteMessage("\n" + oic.Count);
 thats the code i am currently trying with, and the exception occurs at vl.IntersectWith();
Exception details:
Autodesk.AutoCAD.Runtime.Exception: eNotImplementedYet
at Autodesk.AutoCAD.DatabaseServices.Entity.IntersectWith(Entity entityPointer, Intersect intersectType, Point3dCollection points, IntPtr thisGraphicSystemMarker, IntPtr otherGraphicSystemMarker)
at AcadPlugin.MyCommands.MyIntersection() in e:\DEV\AcadPlugin1.0\AcadPlugin1.0\Commands.cs:Zeile 154.}	System.Exception {Autodesk.AutoCAD.Runtime.Exception}
ent = {Autodesk.AutoCAD.DatabaseServices.Solid3d}
so = [Autodesk.AutoCAD.EditorInput.CrossingOrWindowSelectedObject] = {
(((8754286416000),Crossing,6,)
(InfiniteLine,(30825.1342620582,30781.8322475576,4200.53349038419),(-0.577350269189626,-0.577350269189626,-0.577350269189626))
(InfiniteLine,(30315.8322765267,31291.1342330891,4200.53349038419),(-0.577350269189626,-0.5773502691...
 Hope this helps.
Valued Mentor
175 Kudos
Post 16 of 16
03-12-2013 10:09 PM in reply to: e1028439
Autodesk hasn't added support for finding intersections with 3D Solid objects and surfaces.
To do that, you will need to use the BoundaryRepresentation API, and is far more complicated than what has been described thus far.
AutoCAD is 3D CADD mainly in terms of its ability to create 3D objects, but is severely crippled in terms of 3D API functionality, and to a lesser-extent, 3D editing and analytical  functionality.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
