.NET
Way of getting all objects between two points.
15 REPLIES 15
Message 1 of 16
e1028439
1699 Views, 15 Replies
Hey all.
Is there any way of getting ALL objects a Line/ray intersects with?
I am thinking of something like:
*Pseudocode*
Ray ray = new Ray();
ray.To = dest;
ray.From = start;
ray.Fire(); var obj = ray.GetFirstHitObject(); /* or null if nothing */ // continue here //
 I don't even need the object, a simple true if it hits something, or false if not is enough for me.
Greetings from Austria,
Thomas
15 REPLIES 15
Message 2 of 16
The Entity class has an IntersectWith() method that tells if the entity  intersects another Entity.
Message 3 of 16
hgasty1001
in reply to: e1028439
If you are trying to select the objects intersected, you can use Editor.SelectFence(fencePoints, SomeFilter). If you need the intersection points, then use both fence selection to obtain the objects  and TT suggestion of IntersectWith to get the points.
Gaston Nunez
Message 4 of 16
Thank you, but that was not the question.
Message 5 of 16
It wasn't the question, it was one answer to how to do what the question asked.
You can also try Gaston's suggestion, assuming all the candidate objects are visible in the current view.
Message 6 of 16
Ok! You have to iterate ALL entities in current space (ModelSpace or PaperSpace) and find intersection of entities and yours line/ray. Method with Editor.SelectFence has so many restrictions...
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 7 of 16
Could you enlighten me about the restrictions of SelectFence()? the only thing i need is to know IF there is something in the way, neither what, nor how big it is.
And if i would give SelectFence a Point modell of a cube for example, would it get all objects that intersect with it?
Thanks again for all the answers 🙂
Message 8 of 16
No. Editor.SelectFence allow to select entities:
1. Visible on active view.
2. Projection of those on active view has intersection with "fence".
3. If entity has not continuous linetype - it will be problem.
4. Zoom factor of current view also affect selection.
5. Allow select entities but not found intersection points - only fact of intersection.
6. Dependent of entities type.
7. Points have to be in UCS (not in WCS)
8. etc.,etc.,etc...
Expert Elite Member
Message 9 of 16
RPeter
I think you need to create a "Virtual Line" (named vl in my code) and do a window selection based on youre 2 points.
The code beneath is not tested but I think it should look like this:
Private Sub MyIntersection()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim db As Database = doc.Database
        Dim p3dc As Point3dCollection = Nothing
        Dim ppo As New PromptPointOptions(vbCrLf & "Select point: ")
        ppo.AllowNone = False
        Dim pt1 As Point3d = ed.GetPoint(ppo).Value
        Dim pt2 As Point3d = ed.GetPoint(ppo).Value
        Dim psr As PromptSelectionResult = ed.SelectWindow(pt1, pt2)
        Dim vl As New Line(pt1, pt2)
        Dim oic As New ObjectIdCollection
        If psr.Status = PromptStatus.OK Then
            Using dl As DocumentLock = doc.LockDocument
                Using tr As Transaction = db.TransactionManager.StartTransaction
                    For Each so As SelectedObject In psr.Value
                        p3dc = Nothing
                        Dim ent As Entity = TryCast(tr.GetObject(so.ObjectId, OpenMode.ForRead), Entity)
                        Try
                            vl.IntersectWith(ent, Intersect.ExtendBoth, p3dc, 0, 0)
                            If p3dc.Count > 0 Then
                                oic.Add(ent.ObjectId)
                            End If
                        Catch
                        End Try
                    Next
                End Using
                'Now youre intersecting objects are in the oic (objectIdCollection)
            End Using
        End If
    End Sub
 Regards
Peter
Message 10 of 16
e1028439
in reply to: RPeter
 Regards
Peter
Dear Peter, i modified your code a little bit to use Editor.SelectCrossingWindow, and now it throws a eNotImplementedYet exeption on the following line >vl.IntersectWith()<.
I needed to change to SelectCrossingWindow because i need all objects i hit, not only the ones i completely surround.
Greetings
Thomas
Message 11 of 16
What kind of entity (name of class) was intersected?
I also recommend to use Intersect.OnBothOperands instead of Intersect.ExtendBoth because many kind of entities can not be extended.
Expert Elite Member
Message 12 of 16
it was an InfiniteLine, and i tried all 4 of the possible intersect enum types, all throw the same eNotImplementedYet exception
Message 13 of 16
The code you're trying to use doesn't work as posted because it passes null to IntersectWith() in the argument that requires a Point3dCollection.
That may be what is causing the exception.  Create a new Point3dCollection and call it's Clear() method just before each call to IntersectWith().
Message 14 of 16
The base AutoCAD product API has no class called "InfiniteLine".
The XLine is an infinite line, so perhaps that's what you meant?
Message 15 of 16
var doc = Application.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            var db = doc.Database;
            var ppo = new PromptPointOptions("\nSelect point: ") { AllowNone = false };
            var pt1 = ed.GetPoint(ppo).Value;
            var pt2 = ed.GetPoint(ppo).Value;
            var psr = ed.SelectCrossingWindow(pt1, pt2);
            var vl = new Line(pt1, pt2);
            var oic = new ObjectIdCollection();
            if (psr.Status != PromptStatus.OK)
                return;
            using (var dl = doc.LockDocument())
                using (var tr = db.TransactionManager.StartTransaction())
                    Point3dCollection p3dc;
                    foreach (SelectedObject so in psr.Value)
                        p3dc = new Point3dCollection();
                        var ent = tr.GetObject(so.ObjectId, OpenMode.ForRead) as Entity;
                        try
                            vl.IntersectWith(ent, Intersect.OnBothOperands, p3dc, new IntPtr(), new IntPtr());
                            if (ent != null && p3dc.Count > 0)
                                oic.Add(ent.ObjectId);
                        catch (Exception) { }
            ed.WriteMessage("\n" + oic.Count);
 thats the code i am currently trying with, and the exception occurs at vl.IntersectWith();
Exception details:
Autodesk.AutoCAD.Runtime.Exception: eNotImplementedYet
at Autodesk.AutoCAD.DatabaseServices.Entity.IntersectWith(Entity entityPointer, Intersect intersectType, Point3dCollection points, IntPtr thisGraphicSystemMarker, IntPtr otherGraphicSystemMarker)
at AcadPlugin.MyCommands.MyIntersection() in e:\DEV\AcadPlugin1.0\AcadPlugin1.0\Commands.cs:Zeile 154.}	System.Exception {Autodesk.AutoCAD.Runtime.Exception}
ent = {Autodesk.AutoCAD.DatabaseServices.Solid3d}
so = [Autodesk.AutoCAD.EditorInput.CrossingOrWindowSelectedObject] = {
(((8754286416000),Crossing,6,)
(InfiniteLine,(30825.1342620582,30781.8322475576,4200.53349038419),(-0.577350269189626,-0.577350269189626,-0.577350269189626))
(InfiniteLine,(30315.8322765267,31291.1342330891,4200.53349038419),(-0.577350269189626,-0.5773502691...
 Hope this helps.
Message 16 of 16
Autodesk hasn't added support for finding intersections with 3D Solid objects and surfaces.
To do that, you will need to use the BoundaryRepresentation API, and is far more complicated than what has been described thus far.
AutoCAD is 3D CADD mainly in terms of its ability to create 3D objects, but is severely crippled in terms of 3D API functionality, and to a lesser-extent, 3D editing and analytical  functionality.
”Boost
