.NET
Valued Contributor
hericson
Message 1 of 15 (485 Views)
WaitCursor at the command line
485 Views, 14 Replies
08-11-2009 02:14 AM
To display the wait cursor when using a form I use System.Windows.Forms Namespace like this (VB.NET):
System.Windows.Forms.Cursor = Cursors.WaitCursor
But how should I do if I don't use a form? I ask for some options from the command line and while executing my code I want to display a wait cursor (still VB.NET).
*Terry W. Dotson
Message 2 of 15 (484 Views)
Re: WaitCursor at the command line
08-11-2009 07:10 AM in reply to: hericson
Have you considered using a ProgressMeter instead? If you know the
number of iterations it seems like a better option.
Terry
Valued Contributor
hericson
Message 3 of 15 (484 Views)
08-13-2009 01:43 AM in reply to: hericson
Yes, I have considered that. But I have some problems with the progress meter, testing using a simple for next loop from 1 to 100 it will count all the percents but when using in it my real case it will only show every 6 percents and I can't figure out why.
Secondly I think it should be one way to show an hourglass without a form.
Distinguished Contributor
NathTay
Message 4 of 15 (484 Views)
08-13-2009 05:29 AM in reply to: hericson
Are there only 16 or 17 loops in your real world example?
Valued Contributor
hericson
Message 5 of 15 (484 Views)
08-13-2009 05:59 AM in reply to: hericson
I had over 5000 loops but I found out that the order of pm.Start and pm.SetLimit made a difference (pm.Start first) and I also had to add pm.Dispose after pm.Stop to get it to work so that's not a problem anymore.
*Tony Tanzillo
Message 6 of 15 (484 Views)
08-13-2009 03:56 PM in reply to: hericson
You can reference System.Windows.Forms from any app,
even if it doesn't use any forms or UI components.
If for some reason you need to avoid referencing WinForms,
the only other option is P/Invoking the SetCursor() API
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6234752@discussion.autodesk.com...
(still VB.NET).
*Hericson
Message 7 of 15 (484 Views)
08-14-2009 06:19 AM in reply to: hericson
Can you give an example with the correct namespace because when I try
with: System.Windows.Forms.Cursor = Cursors.WaitCursor I'll get an error
message: 'Cursor' is an type in 'Forms' and cannot be use as an expression.
If I have a form I just have this code: Me.Cursor = Cursors.WaitCursor
*Tony Tanzillo
Message 8 of 15 (484 Views)
08-14-2009 07:48 AM in reply to: hericson
Here's what I use:
{code}
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
namespace MyNamespace
public class CurrentCursor : IDisposable
private Cursor saved = Cursor.Current;
public CurrentCursor( Cursor newCursor )
Cursor.Current = newCursor;
public void Dispose()
Cursor.Current = this.saved;
public class WaitCursor : CurrentCursor
public WaitCursor()
: base( Cursors.WaitCursor )
// example usage:
public class MyCommands
[CommandMethod("MYCOMMAND")
public static void MyCommand()
using( new WaitCursor() )
// wait cursor is visible here,
// so do what you need to do
} // the prevous cursor is restored here.
{code}
"Hericson" wrote in message
news:6237315@discussion.autodesk.com...
Valued Contributor
hericson
Message 9 of 15 (484 Views)
08-15-2009 05:30 AM in reply to: hericson
Sorry but I'm not able to convert your sample to VB.NET (lack of skills I guess). I think I can understand the example but not how to make the two classes into VB.NET.
NathTay
Message 10 of 15 (484 Views)
08-15-2009 06:38 PM in reply to: hericson
Imports System.Windows.Forms
Imports Autodesk.AutoCAD.Runtime
Namespace MyNamespace
    Public Class CurrentCursor
        Implements IDisposable
        Private saved As Cursor = Cursor.Current
        Public Sub New(ByVal newCursor As Cursor)
        End Sub
        Public Sub Dispose()
            Cursor.Current = Me.saved
        End Sub
    End Class
    Public Class WaitCursor
        Inherits CurrentCursor
        Public Sub New()
            MyBase.New(Cursors.WaitCursor)
        End Sub
    End Class
    ' example usage:
    Public Class MyCommands
        _
        Public Shared Sub MyCommand()
            Using New WaitCursor()
                ' wait cursor is visible here,
                ' so do what you need to do
                ' the prevous cursor is restored here.
            End Using
        End Sub
    End Class
End Namespace
