.NET
mfernandes
Message 1 of 6 (193 Views)
VSE 2013 debugger
193 Views, 5 Replies
04-25-2014 12:54 PM
Any have success using visual  studio 2013 vb.net and AutoCAD 2014 win7/64
I get the following when I select the start debugging.
"In order to debug this project, add an executable project to this solution which references the library project. Set the executable project as the startup project."
Not sure as i don`t use VSE, but I think that message refers to add the Autocad executable to the project, and set that exe as startup project, see this link third method:Debuggin
Gaston Nunez
Valued Mentor
gasty1001
Message 2 of 6 (186 Views)
Re: VSE 2013 debugger
04-25-2014 01:20 PM in reply to: mfernandes
Gaston Nunez
mfernandes
Message 3 of 6 (176 Views)
04-25-2014 01:50 PM in reply to: gasty1001
thanks Gaston Nunez
mfernandes
Message 4 of 6 (150 Views)
04-26-2014 11:41 AM in reply to: mfernandes
any idea why when I select , Debug, Start command
my dll is not rebuild with the changes.
I am sure in VBE 2010 it built my dll via the debug command and I simpley had to netload in AutoCAD
I cannot find where I need to set this in VSE2013
Valued Mentor
gasty1001
Message 5 of 6 (143 Views)
04-26-2014 01:33 PM in reply to: mfernandes
I don't know if this work in Express, but in VS you have to go to Tools Menu->Options->Projects and Solutions->Build and Run and set your preferences there.
Gaston Nunez
mfernandes
Message 6 of 6 (139 Views)
04-26-2014 01:47 PM in reply to: mfernandes
this is what I have for settings and it would seem that my dll should be build and saved in the bin\Debug\ folder.
But the only time this happens is if I select the build command.
OK I just figured it out.
Seem you have to uncheck the "Only build startup projects and dependencies on Run"
is this correct?
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
