.NET
Distinguished Contributor
3 Kudos
Post 1 of 4
VS Not jumping to problem.
154 Views, 3 Replies
08-27-2013 09:16 AM
Good afternoon group,
Visual Studio has stopped jumping to the error if there is a problem
with my code.  For instance, if I left a Dialog open in AutoCad then if
I paused it would hit the same line every time, similar to this:
Dim myForm As New LoadMyDialog
ShowModalDialog(myForm)  (<-- THIS ONE)
Now it just does nothing.  It's very annoying, any ideas?
Ta,
Martin.
My name is Martin.. :smileyvery-happy:
Try setting NEXTFIBERWORLD=0 in AutoCAD (need a restart of AutoCAD)
Gaston Nunez
Distinguished Mentor
91 Kudos
Post 2 of 4
Re: VS Not jumping to problem.
08-27-2013 10:25 AM in reply to: quigs
Gaston Nunez
3 Kudos
Post 3 of 4
08-27-2013 10:38 AM in reply to: gasty1001
That worked,
Thank you so much. :d
91 Kudos
Post 4 of 4
08-27-2013 11:00 AM in reply to: gasty1001
Glad to help. I forgot to mention that setting fibers to 0 set AutoCAD in a diminished state, some things will not function properly  , this thread may help you to understand the situation: FIBERWORLD .
Gaston Nunez
