Hi Frane,
I would suspect it is exactly the same problem as my post directly before
yours. VS 2010 has suddenly got very picky about framework versions. You
will have to make sure the target framework on your dll is at least the same
as the autodesk.map.platform.dll you are compiling against. If you want to
keep the same target framework on your dll then you will have to get an
older version of autodesk.map.platform.dll to compile against.
Adam
"kob4lt" wrote in message news:6372676@discussion.autodesk.com...
> Does anyone having problem with adding a reference with this dll?
> When I add reference in visual studio 2010 on autodesk.map.platform.dll,
> object browser said it has no namespaces.
> In Visual studio 2008, everthing was working fine
> Thanks
> Frane
