Is there anyone want to try this on your computer?
Create a dwg with a xref, set VISRETAIN to 1. Freeze some layer and change color for some layer of the xref. Save the file.
Next time when you open the file those layers should stay at the same status as you saved.
Now try to open the dwg with DATABASE.ReadDwgFile(). Make some change if you want then save the dwg with DATABASE.SaveAs(). Open the dwg in ACAD and see if those layer stay at the same status as you saved.
On my computer I can see the DATABASE.VISRETAIN property is TRUE after ReadDwgFile(), but xref status can't be retained after the dwg been saved by DATABASE.SaveAs().
Any response is appreciated.
I can't replicate this issue. It works as expected for me. VISRETAIN remembers the settings I had before and after executing the following.
Autocad Map 3D 2010
VS 2008
Option Explicit On Option Strict On 'reference acmgd Imports Autodesk.AutoCAD.Runtime 'reference acdbmgd Imports Autodesk.AutoCAD.DatabaseServices 'others 'reference system.drawing Imports System.Drawing Public Class VisTest <CommandMethod("vistest")> _ Sub starthere() Dim dwgfile As String = "d:\acad\drawings\vistest.dwg" Dim myDB As New Autodesk.AutoCAD.DatabaseServices.Database myDB.ReadDwgFile(dwgfile, IO.FileShare.ReadWrite, True, "") Dim msg As String = "Visretain is " If myDB.Visretain = True Then msg = msg & "on" Else msg = msg & "off" End If MsgBox(msg) Using mytx As Transaction = myDB.TransactionManager.StartTransaction Dim vislayertable As LayerTable = CType(mytx.GetObject(myDB.LayerTableId, OpenMode.ForWrite), LayerTable) If Not vislayertable.Has("test") Then Dim newlayer As LayerTableRecord = New LayerTableRecord _ With {.Name = "test", .Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Red)} vislayertable.Add(newlayer) mytx.AddNewlyCreatedDBObject(newlayer, True) End If mytx.Commit() End Using myDB.SaveAs(dwgfile, DwgVersion.AC1800) myDB.Dispose() Dim xreffile As String = "d:\acad\drawings\xrefthis.dwg" Dim myXrefDB As New Autodesk.AutoCAD.DatabaseServices.Database myXrefDB.ReadDwgFile(xreffile, IO.FileShare.ReadWrite, True, "") Using mytx As Transaction = myXrefDB.TransactionManager.StartTransaction Dim xreflayertable As LayerTable = CType(mytx.GetObject(myXrefDB.LayerTableId, OpenMode.ForWrite), LayerTable) If Not xreflayertable.Has("test") Then Dim newlayer As LayerTableRecord = New LayerTableRecord _ With {.Name = "test", .Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Red)} xreflayertable.Add(newlayer) mytx.AddNewlyCreatedDBObject(newlayer, True) End If mytx.Commit() End Using myXrefDB.SaveAs(xreffile, DwgVersion.AC1800) myXrefDB.Dispose() End Sub End Class
Thank you for quick reply.
I saw it last Friday. I notice one different in your code that is :
where in my code I use:
dbdest.ReadDwgFile(sheetdwgfilename, IO.FileShare.ReadWrite,False, "")
After I changed the False to True, I got exception "Object reference not set to an instance of an object." at the statement of
dbdest.SaveAs(sheetdwgfilename, DwgVersion.Current)
which in your code is :
But even I got the exception, the file was saved with my change, and the status of the xref was retained as what I want.
The problem half solved.
Do you have any idea of this exception?
Thank you.
If you post your code I will try it - it's hard to tell without seeing it.
I would suspect a problem with your definition of sheetdwgfilename.
I should have added that we are still using Autocad 2004 as our standard DWG file format. Autocad 2004 = DWGVERSION.AC1800.
I do have a warning on the definition of sheetdwgfilename which is used before New(). Now I have no exception on SaveAs, but Visretain still not work.
Later I realize I have a statement before SaveAs:
dbdest.ResolveXrefs(True, False)
This is the reason my xref status changed. After I comment it the problem gone.
Thank you for your time. I didn't post my code as I have OpengDWG and SaveAs in different sub and dbdest is a private member in Class. I made it too complex and don't want make you confused.
Have a nice weekend.
Bit late, but you may want to refer to:
http://forums.autodesk.com/t5/NET/VISRETAIN-and-Purge/m-p/3807545/highlight/false
Dale
