.NET
11 Kudos
Post 1 of 3
VISRETAIN and Purge
186 Views, 2 Replies
03-17-2013 05:15 AM
I have a PurgeAll tool which appears to work well, however when used in batch mode the xref layer settings are lost. VISRETAIN remains correctly set. If I run the identical purge code on the current file (ie not using db.ReadDwgFile) then the layers are unaffected. I have tried save/restore LayerState before and after, but again the batch process mangles it, whereas on the current file it all behaves perfectly. This post seems to be closest to a similar problem: http://forums.autodesk.com/t5/NET/VISRETAIN-not-work-with-ReadDwgFile/m-p/3122828/highlight/true#M24... I have included trimmed code below. Many thanks for any thoughts. Dale
<code>
PROCESS:
purgeAllFiles>purgeAll>purgeDictionaries+purgeSymbolTables
CODE:
public static void purgeAllFiles(string pstrSourceFolderName, string pstrTargetFolderName, string pstrTargetFileNameSuffix)
            Document doc = AcadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            string pathName = pstrSourceFolderName;
            string[] fileNames = FolderTools.getFilesInFolder(pstrSourceFolderName, "*.dwg", lsoFolderSearchOption);
            foreach (string lstrFileName in fileNames)
                if (lstrFileName.EndsWith(".dwg", StringComparison.CurrentCultureIgnoreCase))
                    string lstrFileNameOutput = FolderTools.getTargetFileNameFull(pstrTargetFolderName, lstrFileName, pstrTargetFileNameSuffix);
                    Database db = new Database(false, true);
                    try
                        db.ReadDwgFile(lstrFileName, FileOpenMode.OpenForReadAndWriteNoShare, true, "");
                        db.RetainOriginalThumbnailBitmap = true;
                        string lstrMessage = string.Empty;
                        using (Transaction tr = db.TransactionManager.StartTransaction())
                            // save Layer State "ATK_PurgeAll"
                            string lstrLayerStateName = "ATK_PurgeAll";
                            LayerStateTools.saveLayerStateAllProps(db, tr, lstrLayerStateName);
                            // this is recursive, no need for extra process
                           purgeAll(db, tr, true);
                            // restore Layer State "ATK_PurgeAll"
                            LayerStateTools.setLayerStateAllProps(db, tr, lstrLayerStateName);
                            tr.Commit();
                        db.SaveAs(lstrFileNameOutput, true, DwgVersion.Current, db.SecurityParameters);
                    catch (System.Exception ex)
                        ed.WriteMessage("\nProblem");
            ed.WriteMessage("\nSuccess");
public static bool purgeAll(Database pdb, Transaction ptr, bool pblnSilent)
            // tables
            ObjectIdCollection tableIds = new ObjectIdCollection();
            tableIds.Add(pdb.BlockTableId);
            tableIds.Add(pdb.DimStyleTableId);
            tableIds.Add(pdb.LayerTableId);
            tableIds.Add(pdb.LinetypeTableId);
            tableIds.Add(pdb.RegAppTableId);
            tableIds.Add(pdb.TextStyleTableId);
            tableIds.Add(pdb.UcsTableId);
            tableIds.Add(pdb.ViewportTableId);
            tableIds.Add(pdb.ViewTableId);
            // dictionaries
            ObjectIdCollection dictIds = new ObjectIdCollection();
            dictIds.Add(pdb.MaterialDictionaryId);
            dictIds.Add(pdb.MLStyleDictionaryId);
            dictIds.Add(pdb.MLeaderStyleDictionaryId);
            dictIds.Add(pdb.PlotStyleNameDictionaryId);
            dictIds.Add(pdb.TableStyleDictionaryId);
            dictIds.Add(pdb.VisualStyleDictionaryId);
            // recursive
            while (purgeSymbolTables(pdb, ptr, tableIds, pblnSilent) || purgeDictionaries(pdb, ptr, dictIds, pblnSilent))
                continue;
            return true;
public static bool purgeSymbolTables(Database pdb, Transaction ptr, ObjectIdCollection pTableIds, bool pblnSilent)
            bool itemsPurged = false;
            Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            ObjectIdCollection purgeableIds = new ObjectIdCollection();
            foreach (ObjectId id in pTableIds)
                SymbolTable table = ptr.GetObject(id, OpenMode.ForRead, false) as SymbolTable;
                foreach (ObjectId recordId in table)
                    purgeableIds.Add(recordId);
            pdb.Purge(purgeableIds);
            if (purgeableIds.Count == 0)
                return false;
            itemsPurged = true;
            foreach (ObjectId id in purgeableIds)
                try
                    SymbolTableRecord record = ptr.GetObject(id, OpenMode.ForWrite) as SymbolTableRecord;
                    string recordName = record.Name;
                    record.Erase();
                    if (!pblnSilent)
                        if (!recordName.Contains("|"))
                            ed.WriteMessage("\nPurging " + record.GetType().Name + " " + recordName);
                catch (Autodesk.AutoCAD.Runtime.Exception e)
                    if ((e.ErrorStatus == ErrorStatus.CannotBeErasedByCaller) || (e.ErrorStatus == (ErrorStatus)20072))
                    else
                        throw e;
            return itemsPurged;
        public static bool purgeDictionaries(Database pdb, Transaction ptr, ObjectIdCollection pDictIds, bool pblnSilent)
            foreach (ObjectId id in pDictIds)
                DBDictionary dict = ptr.GetObject(id, OpenMode.ForRead, false) as DBDictionary;
                foreach (DBDictionaryEntry de in dict)
                    purgeableIds.Add(de.m_value);
                return false;
            itemsPurged = true;
            DBDictionary nod = ptr.GetObject(pdb.NamedObjectsDictionaryId, OpenMode.ForRead) as DBDictionary;
                try
                    DBObject obj = ptr.GetObject(id, OpenMode.ForWrite) as DBObject;
                    obj.Erase();
                    if (!pblnSilent)
                        foreach (ObjectId dictId in pDictIds)
                            DBDictionary dict = ptr.GetObject(dictId, OpenMode.ForRead, false) as DBDictionary;
                            string dictName = nod.NameAt(dictId);
                            if (dict.Contains(id))
                                ed.WriteMessage("\nPurging " + dict.NameAt(id) + " from " + dictName);
                                break;
                    else
                        throw e;
            return itemsPurged;
<code>
Valued Mentor
53 Kudos
Post 2 of 3
Re: VISRETAIN and Purge
03-17-2013 09:56 PM in reply to: Dale.Bartlett
Just guessing but,
does calling CloseInput(True) after ReadDwgFile make a difference?
You can also find your answers @ TheSwamp
11 Kudos
Post 3 of 3
03-17-2013 10:05 PM in reply to: jeff
In a moment of insight after a sleepless night, it came to me: Resolve the Xrefs before processing
<code>
db.ResolveXrefs(true, false);
<code>
Hope this is helpful for another poor soul.
Dale
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
