.NET
Distinguished Contributor
Dale.Bartlett
Message 1 of 3 (168 Views)
VISRETAIN and Purge
168 Views, 2 Replies
03-17-2013 05:15 AM
I have a PurgeAll tool which appears to work well, however when used in batch mode the xref layer settings are lost. VISRETAIN remains correctly set. If I run the identical purge code on the current file (ie not using db.ReadDwgFile) then the layers are unaffected. I have tried save/restore LayerState before and after, but again the batch process mangles it, whereas on the current file it all behaves perfectly. This post seems to be closest to a similar problem: http://forums.autodesk.com/t5/NET/VISRETAIN-not-work-with-ReadDwgFile/m-p/3122828/highlight/true#M24... I have included trimmed code below. Many thanks for any thoughts. Dale
<code>
PROCESS:
purgeAllFiles>purgeAll>purgeDictionaries+purgeSymbolTables
CODE:
public static void purgeAllFiles(string pstrSourceFolderName, string pstrTargetFolderName, string pstrTargetFileNameSuffix)
            Document doc = AcadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            string pathName = pstrSourceFolderName;
            string[] fileNames = FolderTools.getFilesInFolder(pstrSourceFolderName, "*.dwg", lsoFolderSearchOption);
            foreach (string lstrFileName in fileNames)
                if (lstrFileName.EndsWith(".dwg", StringComparison.CurrentCultureIgnoreCase))
                    string lstrFileNameOutput = FolderTools.getTargetFileNameFull(pstrTargetFolderName, lstrFileName, pstrTargetFileNameSuffix);
                    Database db = new Database(false, true);
                    try
                        db.ReadDwgFile(lstrFileName, FileOpenMode.OpenForReadAndWriteNoShare, true, "");
                        db.RetainOriginalThumbnailBitmap = true;
                        string lstrMessage = string.Empty;
                        using (Transaction tr = db.TransactionManager.StartTransaction())
                            // save Layer State "ATK_PurgeAll"
                            string lstrLayerStateName = "ATK_PurgeAll";
                            LayerStateTools.saveLayerStateAllProps(db, tr, lstrLayerStateName);
                            // this is recursive, no need for extra process
                           purgeAll(db, tr, true);
                            // restore Layer State "ATK_PurgeAll"
                            LayerStateTools.setLayerStateAllProps(db, tr, lstrLayerStateName);
                            tr.Commit();
                        db.SaveAs(lstrFileNameOutput, true, DwgVersion.Current, db.SecurityParameters);
                    catch (System.Exception ex)
                        ed.WriteMessage("\nProblem");
            ed.WriteMessage("\nSuccess");
public static bool purgeAll(Database pdb, Transaction ptr, bool pblnSilent)
            // tables
            ObjectIdCollection tableIds = new ObjectIdCollection();
            tableIds.Add(pdb.BlockTableId);
            tableIds.Add(pdb.DimStyleTableId);
            tableIds.Add(pdb.LayerTableId);
            tableIds.Add(pdb.LinetypeTableId);
            tableIds.Add(pdb.RegAppTableId);
            tableIds.Add(pdb.TextStyleTableId);
            tableIds.Add(pdb.UcsTableId);
            tableIds.Add(pdb.ViewportTableId);
            tableIds.Add(pdb.ViewTableId);
            // dictionaries
            ObjectIdCollection dictIds = new ObjectIdCollection();
            dictIds.Add(pdb.MaterialDictionaryId);
            dictIds.Add(pdb.MLStyleDictionaryId);
            dictIds.Add(pdb.MLeaderStyleDictionaryId);
            dictIds.Add(pdb.PlotStyleNameDictionaryId);
            dictIds.Add(pdb.TableStyleDictionaryId);
            dictIds.Add(pdb.VisualStyleDictionaryId);
            // recursive
            while (purgeSymbolTables(pdb, ptr, tableIds, pblnSilent) || purgeDictionaries(pdb, ptr, dictIds, pblnSilent))
                continue;
            return true;
public static bool purgeSymbolTables(Database pdb, Transaction ptr, ObjectIdCollection pTableIds, bool pblnSilent)
            bool itemsPurged = false;
            Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            ObjectIdCollection purgeableIds = new ObjectIdCollection();
            foreach (ObjectId id in pTableIds)
                SymbolTable table = ptr.GetObject(id, OpenMode.ForRead, false) as SymbolTable;
                foreach (ObjectId recordId in table)
                    purgeableIds.Add(recordId);
            pdb.Purge(purgeableIds);
            if (purgeableIds.Count == 0)
                return false;
            itemsPurged = true;
            foreach (ObjectId id in purgeableIds)
                try
                    SymbolTableRecord record = ptr.GetObject(id, OpenMode.ForWrite) as SymbolTableRecord;
                    string recordName = record.Name;
                    record.Erase();
                    if (!pblnSilent)
                        if (!recordName.Contains("|"))
                            ed.WriteMessage("\nPurging " + record.GetType().Name + " " + recordName);
                catch (Autodesk.AutoCAD.Runtime.Exception e)
                    if ((e.ErrorStatus == ErrorStatus.CannotBeErasedByCaller) || (e.ErrorStatus == (ErrorStatus)20072))
                    else
                        throw e;
            return itemsPurged;
        public static bool purgeDictionaries(Database pdb, Transaction ptr, ObjectIdCollection pDictIds, bool pblnSilent)
            foreach (ObjectId id in pDictIds)
                DBDictionary dict = ptr.GetObject(id, OpenMode.ForRead, false) as DBDictionary;
                foreach (DBDictionaryEntry de in dict)
                    purgeableIds.Add(de.m_value);
                return false;
            itemsPurged = true;
            DBDictionary nod = ptr.GetObject(pdb.NamedObjectsDictionaryId, OpenMode.ForRead) as DBDictionary;
                try
                    DBObject obj = ptr.GetObject(id, OpenMode.ForWrite) as DBObject;
                    obj.Erase();
                    if (!pblnSilent)
                        foreach (ObjectId dictId in pDictIds)
                            DBDictionary dict = ptr.GetObject(dictId, OpenMode.ForRead, false) as DBDictionary;
                            string dictName = nod.NameAt(dictId);
                            if (dict.Contains(id))
                                ed.WriteMessage("\nPurging " + dict.NameAt(id) + " from " + dictName);
                                break;
                    else
                        throw e;
            return itemsPurged;
<code>
Valued Mentor
jeff
Message 2 of 3 (143 Views)
Re: VISRETAIN and Purge
03-17-2013 09:56 PM in reply to: Dale.Bartlett
Just guessing but,
does calling CloseInput(True) after ReadDwgFile make a difference?
You can also find your answers @ TheSwamp
Dale.Bartlett
Message 3 of 3 (141 Views)
03-17-2013 10:05 PM in reply to: jeff
In a moment of insight after a sleepless night, it came to me: Resolve the Xrefs before processing
<code>
db.ResolveXrefs(true, false);
<code>
Hope this is helpful for another poor soul.
Dale
