.NET
Viewport Layers Set To "Frozen" Are Still Visible
22 REPLIES 22
Message 1 of 23
mgorecki
2549 Views, 22 Replies
I have a sub that gets a page number and a collection of layer ID's to freeze.  The sub will freeze the selected layers in all of the viewports except for the new one.
After running the program, the layers in the specific viewport are still visible, but when you go into Model mode in the viewport and check the layer status, it shows the selected layers are set to Freeze in the viewport.
If I save the drawing, exit,and re-open it, the layers are now not visible.  I believe I have the "Regen" in the correct spot.
The code is attached.
    ' Freezes the selected layers in all other existing viewport layouts
    Public Sub freezeOtherLayouts(ByVal pageNumber As Integer, ByVal layersToFreezeLayerIds As ObjectIdCollection)
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim detailLayer As String = "DETAIL_" & pageNumber
        Dim vp As Viewport = Nothing
        Dim viewPortFound As Boolean
        Dim vpIDs As ObjectIdCollection = Nothing
        Dim allLayerIDs As New ObjectIdCollection, detailLayerID As New ObjectIdCollection
        Dim freezeVPtrans As Transaction = Nothing
        Try
            freezeVPtrans = db.TransactionManager.StartTransaction()
            Dim myBT As BlockTable = db.BlockTableId.GetObject(OpenMode.ForRead)
            For Each btrID As ObjectId In myBT
                Dim myBTR As BlockTableRecord = btrID.GetObject(OpenMode.ForRead)
                ' If the block table record is a layout
                If myBTR.IsLayout Then
                    viewPortFound = False
                    If Not myBTR.Name = "*Model_Space" Then
                        Dim layOut As Layout = myBTR.LayoutId.GetObject(OpenMode.ForRead)
                        ' If the layout is the new layout
                        If layOut.TabOrder <> pageNumber Then
                            For Each id As ObjectId In myBTR
                                Dim obj As DBObject = id.GetObject(OpenMode.ForWrite)
                                ' If the object is a viewport (there is a model viewport which is found first, we want the second one)
                                If TypeOf obj Is Viewport And viewPortFound = True Then
                                    Dim vpref As Viewport = DirectCast(obj, Viewport)
                                    ' Selected Viewport for write.
                                    vp = freezeVPtrans.GetObject(vpref.ObjectId, OpenMode.ForWrite)
                                    Dim lt As LayerTable = freezeVPtrans.GetObject(db.LayerTableId, OpenMode.ForRead)
                                    ' Freeze the selected layers in the viewports
                                    vp.FreezeLayersInViewport(layersToFreezeLayerIds.GetEnumerator())
                                    lt.Dispose()
                                End If
                                If TypeOf obj Is Viewport Then
                                End If
                            Next
                        End If
                    End If
                End If
            Next
        Catch
            ed.WriteMessage("Error!")
        Finally
            freezeVPtrans.Commit()
            freezeVPtrans.Dispose()
            ed.Regen()
        End Try
    End Sub
Mark
22 REPLIES 22
Message 2 of 23
Hallex
in reply to: mgorecki
Try add at the end of code:
ed.UpdateTiledViewportsInDatabase()
~'J'~
Message 3 of 23
mgorecki
in reply to: Hallex
I added that to the end of my program, but got an Unhandled Exception ({"eNotApplicable"}).
Message 4 of 23
jeff
Are you sure you not trying to set  on ViewPorts associated with Paperspace?
Might try iterating Database.GetViewports() passing in false.
Input flag indicating whether to return paperspace viewports associated with layouts
You can also find your answers @ TheSwamp
Message 5 of 23
mgorecki
in reply to: jeff
My viewport is in paperspace on layout P1 (I have Model, P1, and P2 layouts).  In order to see what layers are frozen in that particular viewport, I double picked in the viewport, which put me in Model mode.
Message 6 of 23
mgorecki
Hi Jeff,
Can you explain more in regards to "Might try iterating Database.GetViewports() passing in false".  I'm kinda new to VB.Net and I'm still learning.
Mark
Message 7 of 23
jeff
This might work ok if your trying to not freeze the layers in new viewport and has never been Intialized, but would need to intialize any layouts that have never been.
        <CommandMethod("FreezeLayers")> _
        Public Sub MyGroupFreezeLayers() ' This method can have any name
            Using trx As Transaction = db.TransactionManager.StartTransaction
                For Each id As ObjectId In db.GetViewports(False)
                    Dim vp As Viewport = id.GetObject(OpenMode.ForWrite)
                    vp.FreezeLayersInViewport(LayerIds(db).GetEnumerator)
                Next
                trx.Commit()
            End Using
        End Sub
        Private Function LayerIds(ByVal db As Database) As ObjectIdCollection
            Dim layIds As New ObjectIdCollection()
            layIds.Add(db.LayerZero)
            Return layIds
        End Function
Message 8 of 23
mgorecki
in reply to: jeff
Hi Jeff,
I tried using your code but it didn't freeze the selected layer or any layers in the existing viewport in the P1 layout.  I'm still trying to understand the whole "db.GetViewports(False)" thing, maybe that's where my problem is.
Message 9 of 23
jeff
That example should only freeze entites only on layer 0 and only in viewports that have been intialized.
Message 10 of 23
mgorecki
in reply to: jeff
How do I initialize a layout?  Is it layout.initialize()  ?
I'm ready to post my entire program if it would help.  It's driving me crazy already.
I have only one layout in the drawing.  When the code runs, it adds a new layout to the drawing from a template.  A dialog pops up and asks which layers they want to see in the new layouts viewport.  It also asks which layers they do not want to see in all the other layouts viewports (because a new layer was added and if there are many more layouts it will freeze the selected layers in all the other viewports).  When the program is done running, the new layout looks great.  It shows the layers I want to see, but, the existing layout still looks lthe same.  The layers are all still visible, even though the layer manager says that the layers I told to freeze are frozen.  It's like it's just not finishing up and ending the last part.
Here's the code that's supposed to freeze all the selected layers in all the other layouts viewports:
        Dim freezeVPtrans As Transaction = db.TransactionManager.StartTransaction()
        Try
                        ' If the layout is not the new layout
                                    ed.Regen()
                                    lt.Dispose()
                                End If
                                End If
                            Next
                        End If
                    End If
                End If
            Next
        Catch
        Finally
        End Try
    End Sub
 Help!
Message 11 of 23
mgorecki
I changed my code to use GetViewports, so it now looks like this:
        'Dim vp As Viewport = Nothing
        Try
                                vp.FreezeLayersInViewport(layersToFreezeLayerIds.GetEnumerator)
                            Next
                        End If
                    End If
                End If
            Next
        Catch
        Finally
        End Try
    End Sub
 It still leaves the layers visible in the first layout, even though according to the layer manager for that viewport, the layer is frozen.
Message 12 of 23
andre_adc-dao
I think I've found a solution. I had exactly the same problem. After many hours of serch and try (very frustrating), I found that I have to activate the layout before freezing the layers. So I add this sub to my function:
Public Sub SetCurrentLayoutTab(ByVal LayoutName As String)
        Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Using doclock As DocumentLock = acDoc.LockDocument
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                Try
                    Dim acLayoutMgr As LayoutManager
                    acLayoutMgr = LayoutManager.Current
                    acLayoutMgr.CurrentLayout = LayoutName
                    acTrans.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message & vbCr & ex.StackTrace)
                    acTrans.Abort()
                End Try
            End Using
        End Using
    End Sub
Also, this is important to do a regen at the end of your function. Here you will find my complete function (sub). It is different from yours, so give it a try and give me some feedbacks.
   Public Sub FreezeLayerInOtherViewport(ByVal LayerName As String)
            '' Start a transaction
                Dim blockIDs As ObjectIdCollection = New ObjectIdCollection()
                Dim acLyrTbl As LayerTable
                Dim sLayerNames As String = ""
                Dim CVPort As Viewport
                acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForRead)
                For Each acObjId As ObjectId In acLyrTbl
                    Dim acLyrTblRec As LayerTableRecord
                    acLyrTblRec = acTrans.GetObject(acObjId, OpenMode.ForRead)
                    If acLyrTblRec.Name.ToUpper = LayerName.ToUpper Then
                        blockIDs.Add(acLyrTblRec.ObjectId)
                        Exit For
                    End If
                Next
                CVPort = DirectCast(acTrans.GetObject(acDoc.Editor.CurrentViewportObjectId, OpenMode.ForRead), Viewport)
                Dim layoutDict As DBDictionary = CType(acTrans.GetObject(acCurDb.LayoutDictionaryId, OpenMode.ForRead), DBDictionary)
                Dim strCurrentLayoutName As String = LayoutManager.Current.CurrentLayout
                For Each entry As DBDictionaryEntry In layoutDict
                    If entry.Key <> "Model" Then
                        Dim lay As Layout = CType(acTrans.GetObject(entry.Value, OpenMode.ForRead), Layout)
                        If lay.LayoutName.ToUpper <> strCurrentLayoutName Then
                            SetCurrentLayoutTab(lay.LayoutName)
                            Dim nCount As Integer = 0
                            For Each vpid As ObjectId In lay.GetViewports
                                nCount = nCount + 1
                                Dim vp As Viewport = CType(acTrans.GetObject(vpid, OpenMode.ForWrite), Viewport)
                                If vp.Handle <> CVPort.Handle Then
                                    If nCount > 1 Then
                                        vp.FreezeLayersInViewport(blockIDs.GetEnumerator)
                                     End If
                                End If
                            Next
                        End If
                    End If
                Next
                acTrans.Commit()
                SetCurrentLayoutTab(strCurrentLayoutName)
                acDoc.Editor.Regen()
            End Using
        End Using
    End Sub
André
Message 13 of 23
jeff
in reply to: jeff
Sorry I was not very clear but thought I put in early reply and guess not but to call Layout.Initialize() for any un-intialized viewports before setting properties.
Going from memory but I believe that will do it.
Message 14 of 23
mgorecki
in reply to: andre_adc-dao
Hello Andre,
Thank you for your input.  I was able to take some of what you did and integrate it into mine.
        Try
                        'Dim initId As ObjectId = Nothing
                        'initId = layOut.Initialize()
                            SetCurrentLayoutTab(layOut.LayoutName)
                                    Dim layerTable As LayerTable = freezeVPtrans.GetObject(db.LayerTableId, OpenMode.ForRead)
                                    'vp.UpdateDisplay()
                                    ed.Regen()
                                    layerTable.Dispose()
                                End If
                                End If
                            Next
                        End If
                    End If
                End If
            Next
        Catch
        Finally
            ed.Regen()
        End Try
    End Sub
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
                Try
                    acTrans.Commit()
                    acTrans.Abort()
                End Try
            End Using
        End Using
    End Sub
I used your SetCurrentLayoutTab sub, and referenced it inside of the layout loop.  That did the trick and allowed the selected layers to be frozen in the other layout viewports.
Thank you very much!
Mark
Message 15 of 23
andre_adc-dao
Hello Mark,
I'm glad to help you, the only annoying thing is you can see layout change, so the screen is flipping but it is very fast on my computer.
André
Message 16 of 23
Dale.Bartlett
I have the same problem and despite trolling the forums and trying all the suggestions here, no success. I am generating a series of Layouts, then iterating all Layouts to set current (to initialise), then VP Freezing layers. The layers are correctly frozen in the layer dialog box, but continue to display. Regen/Regenall has no effect. Save, Close and re-Open the drawing and the display is correct. I haven't included code as it is mostly as per this thread. Is there something else? Regards, Dale
______________
Yes, I'm Satoshi.
Message 17 of 23
Hallex
in reply to: Dale.Bartlett
Dale, I wrote wrong expression in my first post on this thread,
Try add at the end of code instead
ed.UpdateTiledViewportsFromDatabase()
Message 18 of 23
mgorecki
Hi Dale,
Another thing I found was that AutoCad 2010 is a bit buggy.  Make sure you have the latest service pack.  I downloaded service pack 2 and it fixed the layer visibility issue.  You can tell the service pack you have by going to Help > About.  In the top left mine says version 3 (which in AutoCad land means service pack 2).
Message 19 of 23
Dale.Bartlett
Thanks for the replies. I tried ed.UpdateTiledViewportsFromDatabase(); everywhere but it resulted in errors. As it refers to TiledViewports, it seems that it is not applicable to floating viewports, but I am not sure. I am using AutoCAD 2013 SP1 so it is not an old bug. As I say, it is all correct, and re-opens with the correct display, but needs to be refreshed somehow. Regards, Dale
______________
Yes, I'm Satoshi.
Message 20 of 23
Hi
Though you have mentioned that code is all most same, I would like to request you to provide non confidential code sample with using which we can reproduce the issue at our end. Also, attach a simple non confidential drawing file against which we can reproduce the issue.
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
”Boost
