.NET
Viewport Layer Control?
3 REPLIES 3
2156 Views, 3 Replies
I would like create a new layer and freeze it in all existing layout viewports. I've searched high and low for a vb.net example and have not had any success. If any of you good people could shed some light on how viewport layers are controlled I would be very thankful.
3 REPLIES 3
_gile
The Viewport class provides a FreezeLayersInViewport method...
Gilles Chanteau
GileCAD
GitHub
_gile
Here's a little C# sample (if needed, google for convert C# VB")
{code}using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
namespace ClassLibrary1
public class Class1
[CommandMethod("TEST")]
public static void Test()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
using (Transaction tr = db.TransactionManager.StartTransaction())
// Create a new layer named "Test" color 30
LayerTable lt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForWrite);
if (!lt.Has("Test"))
LayerTableRecord ltr = new LayerTableRecord();
ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, 30);
ltr.Name = "Test";
ObjectId layerId = lt.Add(ltr);
tr.AddNewlyCreatedDBObject(ltr, true);
// Freeze "Test" layer in all viewports
ObjectId[] ids = new ObjectId[1] { layerId };
DBDictionary layoutDict = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
foreach (DBDictionaryEntry entry in layoutDict)
if (entry.Key != "Model")
Layout lay = (Layout)tr.GetObject(entry.Value, OpenMode.ForRead);
foreach (ObjectId vpId in lay.GetViewports())
Viewport vp = (Viewport)tr.GetObject(vpId, OpenMode.ForWrite);
vp.FreezeLayersInViewport(ids.GetEnumerator());
tr.Commit();
{code}
Gilles Chanteau
GileCAD
GitHub
Very useful. Your code has gotten me along way to completing my task. I'm having an issue running my version of your code from a paletteset. I've created a Class Vport with a New() subroutine that creates the layers and a FreezeLayersInAllLayouts() subroutine that freezes the newly created layers in all viewport but the current. A button on the paletteset creates a New Vport class object then freezes the layer then draw some entities in the current viewport. If I step through FreezeLayersInAllLayouts() in the debugger all works fine. If I run FreezeLayersInAllLayouts() without debugging the routine has no effect on the layer state in all the other viewports. See the following code for my adaptation of your code.
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.AutoCAD.Geometry
Public Class Vport
Private CVport As Viewport
Private CVportName As String
Private LayerIds(2) As ObjectId
Public Sub New()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim db As Database = doc.Database
Using DocLock As DocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument()
Using tr As Transaction = db.TransactionManager.StartTransaction()
CVport = DirectCast(tr.GetObject(ed.CurrentViewportObjectId, OpenMode.ForRead), Viewport)
Dim lt As LayerTable = DirectCast(tr.GetObject(db.LayerTableId, OpenMode.ForWrite), LayerTable)
Dim layerid As ObjectId
If Not lt.Has("PH-" + CVport.Handle.ToString()) Then
Dim ltr As LayerTableRecord = New LayerTableRecord()
ltr.Name = "PH-" + CVport.Handle.ToString()
ltr.Color = Color.FromColorIndex(ColorMethod.ByColor, 😎
ltr.ViewportVisibilityDefault = True
layerid = lt.Add(ltr)
LayerIds(0) = layerid
tr.AddNewlyCreatedDBObject(ltr, True)
If Not lt.Has("PT-" + CVport.Handle.ToString()) Then
ltr.Name = "PT-" + CVport.Handle.ToString()
ltr.Color = Color.FromColorIndex(ColorMethod.ByColor, 6)
LayerIds(1) = layerid
If Not lt.Has("PV-" + CVport.Handle.ToString()) Then
ltr.Name = "PV-" + CVport.Handle.ToString()
ltr.Color = Color.FromColorIndex(ColorMethod.ByColor, 3)
LayerIds(2) = layerid
tr.Commit()
End Using
End Using
End Sub
Public Sub FreezeLayersInAllLayouts()
Dim layoutdict As DBDictionary = DirectCast(tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead, False, True), DBDictionary)
For Each entry As DBDictionaryEntry In layoutdict
If entry.Key <> "Model" Then
Dim lay As Layout = DirectCast(tr.GetObject(entry.Value, OpenMode.ForRead, False, True), Layout)
For Each vpid As ObjectId In lay.GetViewports()
Dim vp As Viewport = DirectCast(tr.GetObject(vpid, OpenMode.ForWrite, False, True), Viewport)
If (vp.Handle <> CVport.Handle) Then
vp.FreezeLayersInViewport(LayerIds.GetEnumerator())
Next
Next
tr.Commit()
End Using
End Using
End Sub
Public Sub DrawTimbers(ByVal SS As SelectionSet)
End Sub
End Class
”Boost
