.NET
Valued Contributor
RPeter
Message 1 of 3 (198 Views)
Veto ETRANSMIT command doesn't work
198 Views, 2 Replies
09-13-2013 02:04 AM
I need to Veto ETRANSMIT in some cases, I stripped down my code to a msgbox that will ask if i want to Veto Or not
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
<Assembly: ExtensionApplication(GetType(GHATransmit.Initialization))>
Namespace GHATransmit
    Public Class Initialization
        Implements IExtensionApplication
        Public KillCommand As Boolean = False
        Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
            Dim dm As DocumentCollection = Application.DocumentManager
            Dim doc As Document = dm.MdiActiveDocument
            AddHandler doc.CommandWillStart, New CommandEventHandler(AddressOf StartCommand)
            AddHandler dm.DocumentCreated, New DocumentCollectionEventHandler(AddressOf InstallDoc)
            AddHandler dm.DocumentLockModeChanged, New DocumentLockModeChangedEventHandler(AddressOf LockModeChanged)
        End Sub
        Private Sub InstallDoc()
        End Sub
        Private Sub LockModeChanged(ByVal sender As Object, ByVal e As DocumentLockModeChangedEventArgs)
            If KillCommand Then
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "VETO MY COMMAND (" & KillCommand & ")")
                KillCommand = False
                e.Veto()
            End If
        End Sub
        Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
        End Sub
        Private Sub StartCommand(ByVal o As Object, ByVal e As CommandEventArgs)
            Try
                Dim oCName = e.GlobalCommandName
                If oCName = "ETRANSMIT" Then
                    If MsgBox("Do you want to Veto the ETRANSMIT command?", vbYesNo, "?") = vbYes Then
                        KillCommand = True
                    Else
                        KillCommand = False
                    End If
                End If
            Catch ex As Exception
            End Try
        End Sub
    End Class
End Namespace
 On my command line I can see that the e.veto is triggered.
VETO MY COMMAND (True)
Updating fields...
28 field(s) found
28 field(s) updated
Even if the e.veto has been sent to AutoCAD the ETRANSMIT command still continues
Matti72
Message 2 of 3 (193 Views)
Re: Veto ETRANSMIT command doesn't work
09-13-2013 02:32 AM in reply to: RPeter
Without testing it... are you sure, that the document Lock  change you cancel is indeed the one, which is caused by the eTransmit command?
Maybe you should check the running command in your documentlockchange handler
If (e.GlobalCommandName = "ETRANSMIT") Then
Valued Contributor
RPeter
Message 3 of 3 (189 Views)
09-13-2013 02:40 AM in reply to: RPeter
Original that was in my code.
So I know for sure the correct command is canceled.
