.NET
VBA makes vb.net VS 2003 stop running...
0 REPLIES 0
Message 1 of 1
167 Views, 0 Replies
Hi!
On my work I have makes many vba programs. This works just fine. Now I start
using a VB 2003 vb.net that also works fine until I run
one of my vba programs. After that I only can load my dialog box in the
vb.net application once. The second time it also loads with no problem,
but none of the controls on the dialog box works...Not even the cross in the
upper right corner. But "Esc" butten and "Enter" buten on the
keyboard, same as cancel and OK on dialog box work as normal...
Any idea how what I can do to fix this...
I use AutoCAD 2006
Thanks Rune
0 REPLIES 0
”Boost
