.NET
VB routine to VB.NET
4 REPLIES 4
gizmowiebe
522 Views, 4 Replies
I have a few years experience working with VB6 and VBA in combination with AutoCad. Now due to various reasons I would like to switch to VB.NET. For that I have downloaded Visual Basic 2008 Express.
Attached I added a VB routine that I would like to use in Visual Basic 2008 Express.
Does anybody know how to convert this
Thx in advance.
Wiebe
4 REPLIES 4
fantum
in reply to: gizmowiebe
If you just want to get this into VB.NET pretty much as is then:
1) Create a new project.
2) Paste the code into a suitable place - a button click event in a windows app or Sub Main() of a console app.
3) Add references to the AutoCAD and AutoCAD/ObjectDBX type libraries.
4) Import the namespaces you'll be using (unless you want to fully qualify everything) - Autodesk.AutoCAD.Interop and Autodesk.AutoCAD.Interop.Common.
5) Declare your undeclared variables.
6) Fix your unterminated If blocks and For loop.
7) Enjoy.
Caution: Contents may be hot. Your mileage may vary. Results may not be typical.
No bytes were harmed during the production of this post.
gizmowiebe
Thx fantum for your prompt reply.
I got as far as the function attached. But everytime I get a HRESULT: 0x8007007E error on the blockreference parts.
Any ideas?
Regards
Wiebe
arcticad
Since you are Late Bound you don't have any type defined.
Use typename instead.
{code}
For Each entity In dbxDoc.ModelSpace
If TypeName(entity) = "IAcadBlockReference" Then
MsgBox(entity.name)
End If
Next entity
{code}
(defun botsbuildbots() (botsbuildbots))
fantum
Is there a reason for using late binding?
”Boost
