.NET
VB.net using DWG to PDF.pc3
0 REPLIES 0
Message 1 of 1
823 Views, 0 Replies
I get an error message when I try to use 'plottofile' or 'plottodevice' function. Anybody found a way to use this plotting device?
Private Sub PlotLayout(ByVal Papersize As String, ByVal LayoutName As String)
Dim Configname As String = "PHI - " & Papersize
Dim Path As String
Dim Plots As Integer
Dim PlotConfig As AutoCAD.AcadPlotConfiguration
PlotConfig = GetPlotConfig(Configname & " PDF")
If mform.chkPDFFiles.Checked = True Then
Path = Fullpath & "\" & LayoutName
AcadDwg.Plot.PlotToFile(Path, PlotConfig)
EndIf
EndSub
GetPlotConfig cycles thru configuration types in file until it finds the correct one to use.
I tried 'PlotToDevice' function and adding ".pdf" to path name and nothing seems to work.
Wynn
0 REPLIES 0
”Boost
