.NET
.NET
0 Kudos
Post 1 of 12
VB.net syntax for adding image without frame
290 Views, 11 Replies
05-23-2014 07:41 AM
My VB.NET app uses the code below to insert a JPG image into the drawing.  What is the syntax for making it NOT add the frame around the image?  Thanks in advance.  Mitch
 'Insert Picture
        Dim insertionPoint(2) As Double
        Dim scalefactor As Double
        Dim rotAngleInDegree, rotAngle As Double
        Dim imageName As String
        Dim raster As Autodesk.AutoCAD.Interop.Common.AcadRasterImage
        Dim startPoint(2) As Double
            imageName = "C:\TestImage.jpg"
            insertionPoint(0) = 1.0
            insertionPoint(1) = Tier1BoxHt 'TopEdge - 0.4 'Tier1BoxHt + Tier2BoxHt + Tier3BoxHt / 2 '0.1     '6.1
            scalefactor = 1.0#
            rotAngleInDegree = 0.0#
            rotAngle = rotAngleInDegree * 3.141592 / 180.0#
            raster = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotAngle)
Micropaleontology
Oil Industry
try this: Application.SetSystemVariable("imageframe", 0)
ADN Support Specialist
26 Kudos
Post 2 of 12
Re: VB.net syntax for adding image without frame
05-26-2014 11:16 PM in reply to: BugWare
Drawing of frame around the image is controlled by system variable “IMAGEFRAME”.  You need to set system variable IMAGEFRAME to 0 to avoid drawing of frame around the image. Refer AutoCAD help for different values IMAGEFRAME takes.
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
0 Kudos
Post 3 of 12
05-27-2014 06:50 AM in reply to: Virupaksha.aithal
Thanks very much Virupaksha. That is certainly easy to to do for the end user, but I really need to do this programatically in VB.NET, and not force the end user to do it. Do you know the syntax that I can add to the code shown above in this thread? Thanks again, Mitch
Micropaleontology
Oil Industry
26 Kudos
Post 4 of 12
05-27-2014 08:43 AM in reply to: BugWare
0 Kudos
Post 5 of 12
05-27-2014 09:11 AM in reply to: conormccartney3897
When I try Application.SetSystemVariable("imageframe", 0) I get the compile error:
Error 1 'SetSystemVariable' is not a member of 'System.Windows.Forms.Application'.
I feel like we're getting closer, thanks conormccartney3897.
Micropaleontology
Oil Industry
26 Kudos
Post 6 of 12
05-27-2014 09:13 AM in reply to: BugWare
check your imports up top, look for this, or add if not there: Imports Autodesk.AutoCAD.ApplicationServices
253 Kudos
Post 7 of 12
05-27-2014 09:14 AM in reply to: BugWare
Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("imageframe", 0)
Gilles Chanteau
0 Kudos
Post 8 of 12
05-27-2014 11:16 AM in reply to: _gile
Both solutions by conormccartne3897 and _gile work nicely... sort of. Odd behavior... I've tested this over and over, and it's always the same.
This code does set imageframe to 0.  However, if you exit AutoCAD, it remembers that setting, but the next time you run this code it doesn't work.  You can see that imageframe is set to 0 on the command line.  So if you manually change imageframe to 1, then exit the program, rerun it, the code works again.
So... imageframe has to be already set to 1 for this code to work.  If it's set to 0 to start with, the codewon't work and the image will have a frame.
I just realized while writing this that the simple solution to the problem is to set the imageframe to 1 first, then set it to 0.  An extra line of code, but that does the trick.
Thanks very much!
Micropaleontology
Oil Industry
253 Kudos
Post 9 of 12
05-27-2014 01:32 PM in reply to: BugWare
Don't make unusefull work, just check the current value.
Not certain of VB syntax
Imports AcApp = Autodesk.AutoCAD.ApplicationSevices.Application
If CShort(AcApp.GetSystemVariable("IMAGEFRAME") = 1 Then
    AcApp.SetSystemVariable("IMAGEFRAME", 0)
Gilles Chanteau
26 Kudos
Post 10 of 12
05-27-2014 01:51 PM in reply to: BugWare
hrmm that is odd behavior, but Gilles method makes more sense, use an if statement like so for VB, if its not equal to 0, then switch: If Application.GetSystemVariable("imageframe") <> 0 Then Application.SetSystemVariable("imageframe", 0) End If
