.NET
Active Contributor
AdriDicri
Message 1 of 3 (444 Views)
[VB.NET] Slice 3d Objects?
444 Views, 2 Replies
02-21-2012 07:27 AM
Hi everyone !
Is there any way to slice a 3d object into layers ?
Exemple : a cube, 100*100*100 mm . I want to slice it in 10 layers of 10 milimeters (with the z axis)
My projet is based on autocad. I 'm currently developping an addon to autocad that can get x,y,z coordinates of every shape in the drawing. I'm working with laser machines, and our lasers can only be use between -8 mm and 8 mm.
For 2d drawing, it's simple, i don't need slicing, but for 3d shapes, i need to slice to mark it with our lasers.
Can somebody help me?
thanks a lot.
Adri Dicri
Solid3d s; // 3D solid
Plane p; // slicing plane
Solid3d cutOff; // the part that is sliced away
cutOff = s.Slice(p, true);
Active Member
ivo.zagar
Message 2 of 3 (427 Views)
Re: [VB.NET] Slice 3d Objects?
02-21-2012 12:36 PM in reply to: AdriDicri
Active Contributor
AdriDicri
Message 3 of 3 (407 Views)
02-22-2012 12:36 AM in reply to: AdriDicri
thanks a lot, works great !
