.NET
VB.NET - SET METHOD ON ELLIPSE
2 REPLIES 2
ProfWolfMan
2559 Views, 2 Replies
Hi all,
I am trying to create a ellipse using set method.
But i got 'eGeneralModelingFailure' exception when executing set method.
I can not find any related post about this.
Herewith i attached my code.
Please give a try!
Thanks & Regards,
G
Thanks & Regards,
G
2 REPLIES 2
Hallex
in reply to: ProfWolfMan
Try to rewrite the following Sub DrawEllipse on Function
This will draw an ellipse and ellipse arcs as well
    <CommandMethod("elp")> _
    Public Sub temp()
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
        Dim acEditor As Editor = acDoc.Editor
        Using trans As Transaction = db.TransactionManager.StartTransaction()
            Dim btr As BlockTableRecord = CType(trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
            DrawEllipse(btr, trans, New Point3d(0, 0, 0), 0.6, 20, 0.0, Math.PI * 2.0)
            trans.Commit()
        End Using
    End Sub
    Public Sub DrawEllipse(ByRef btr As BlockTableRecord, ByRef trans As Transaction, _
ByVal origPt As Point3d, ByVal radr As Double, _
ByVal leng As Double, ByVal sang As Double, ByVal eang As Double)
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim x As Vector3d = db.Ucsxdir
        Dim y As Vector3d = db.Ucsydir
        Dim normalVec As Vector3d = x.CrossProduct(y)
        Dim axisvec As Vector3d = normalVec.GetNormal()
        Dim elp As Ellipse = New Ellipse(origPt, _
        axisvec, _
        New Vector3d(0, leng / -2, 0.0), _
        radr, _
        sang, _
        eang)
        btr.AppendEntity(elp)
        trans.AddNewlyCreatedDBObject(elp, True)
    End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
ProfWolfMan
Thank you very much for your help.
When i run your code with my own parameter values to draw ellipse, it returns exception of 'elockviolation'.
then, i add below lines
Using acLckDoc As DocumentLock = acDoc.LockDocument()
....'using transaction
....'end using
End using
It happens all of my code. I dont know where i am wrong?
I am always open blocktable record in openforwrite mode only. even though elockviolation error occurs .
Any idea?
Thanks & regards,
G
Thanks & Regards,
G
”Boost
