.NET
VB .NET Select Existing Table and Read Data
2 REPLIES 2
1938 Views, 2 Replies
I'm trying to convert my existing VBA application to .NET.  The VBA app prompted the user for the selection of the table (a two column table), would read the data, and input it as custom sheetset properties.  I've struggled through the learning curve of importing, running, etc. in the .NET world, but I'm stuck.  The error is somewhere between the reading of the table and passing that information into the sub to insert it into the sheetset manager.  I'm using Win 64bit and Autocad 2013.  Any advice is appreciated.  Code:
Imports ACSMCOMPONENTS19Lib
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Public Class SSManagerProp
    Public ReadOnly Property ThisDrawing As AutoCAD.AcadDocument
        Get
            Return Autodesk.AutoCAD.ApplicationServices.DocumentExtension.GetAcadDocument(Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument)
        End Get
    End Property
    <CommandMethod("TestApp")>
    Public Sub SelectTable()
        'On Error GoTo MyError
        Dim tblObj As AutoCAD.IAcadTable
        Dim tblPt As Object
        Dim sheetsetCount As Integer
        Dim iterDb As IAcSmEnumDatabase
        Dim ItemDb As IAcSmPersist
        sheetSetMgr = New AcSmSheetSetMgr
        iterDb = sheetSetMgr.GetDatabaseEnumerator
        ItemDb = iterDb.Next
        sheetsetCount = 0
        Do While Not ItemDb Is Nothing
            sheetsetCount = sheetsetCount + 1
        Loop
        If sheetsetCount > 1 Then
            MsgBox("There are multiple Sheet Sets Open." & Chr(10) & "You must close all other Sheet Sets.")
            Exit Sub
        ElseIf sheetsetCount = 0 Then
            MsgBox("There is no open Sheet Set." & Chr(10) & "Data was NOT updated.")
            Exit Sub
        End If
        With ThisDrawing.Utility
            .GetEntity(tblObj, tblPt, vbCrLf & "Select table: ")
        End With
        Dim vec0(0 To 2) As Double
        vec0(0) = 0.0# : vec0(1) = 0.0# : vec0(2) = 1.0#
        Dim gotRow As Long, gotCol As Long
        If tblObj.HitTest(tblPt, vec0, gotRow, gotCol) Then
            Dim RowCount As Integer
            RowCount = 0
            Dim SSData(200, 200) As String
            Dim Count As Integer
            Count = 0
            Do While tblObj.GetCellValue(Count, 0) <> ""
                SSData(Count, 0) = tblObj.GetCellValue(Count, 0)
                SSData(Count, 1) = tblObj.GetCellValue(Count, 1)
                Count = Count + 1
            Loop
        End If
        SetSheetSetCustomProp(SSData)
        MsgBox("Successful")
        Exit Sub
MyError:
        MsgBox("You did not select a table.  Try again.")
    End Sub
    Dim sheetSetMgr As IAcSmSheetSetMgr
    Dim sheetdb As IAcSmDatabase
    Private Sub SetSheetSetCustomProp(CustomName As Object)
        Dim sheetCount As Integer
        sheetdb = ItemDb
        '' Lock Database
        LockDatabase()
        Dim i As Integer
        i = 0
        Do While i < 201
            On Error Resume Next
            Dim sheet As IAcSmSheet
            Dim iter As IAcSmEnumPersist
            Dim Item As IAcSmPersist
            iter = sheetdb.GetEnumerator
            Item = iter.Next
            Dim cBag As IAcSmCustomPropertyBag
            Dim cBagVal As New AcSmCustomPropertyValue
            cBag = sheetdb.GetSheetSet().GetCustomPropertyBag
            cBagVal.InitNew(cBag)
            cBagVal.SetFlags(CUSTOM_SHEETSET_PROP)
            cBagVal.SetValue(CustomName(i, 1))
            cBag.SetProperty(CustomName(i, 0), cBagVal)
            cBagVal = Nothing
            i = i + 1
        Loop
        '' Unlock the database
        UnlockDatabase()
    End Sub
    '' Used to Lock the database
    Private Sub LockDatabase()
        Dim lockStatus As AcSmLockStatus
        lockStatus = sheetdb.GetLockStatus
        If lockStatus = AcSmLockStatus.AcSmLockStatus_UnLocked Then
            sheetdb.LockDb(sheetdb)
        End If
    End Sub
    '' Used to Unlock the database
    Private Sub UnlockDatabase()
        If lockStatus = AcSmLockStatus.AcSmLockStatus_Locked_Local Or AcSmLockStatus.AcSmLockStatus_Locked_Remote Then
            sheetdb.UnlockDb(sheetdb)
        End If
    End Sub
    Sub OpenSheetSets()
    End Sub
    Private Function CUSTOM_SHEETSET_PROP() As Object
        Throw New NotImplementedException
    End Function
    Private Function SSData() As Object
    End Function
End Class
2 REPLIES 2
Ok, so I've made some progress.  My problem was in my array declaration/initialization.  I know there are better data structures than arrays, but this is such a simple routine I don't want to learn more than I have to to convert this from VBA 🙂
I now seem to have a different problem.  My program will write the data (I think) to the sheetset.  It's very ungraceful (right now it opens and closes the sheetset database for each value - takes a lot of time).  But I have a weird problem.  When I hover over the sheetset and get the pop-up preview, I see the custom values (image attached).  But when I right-click on the sheetset and edit the custom properties, there are none.  Any ideas about this?
Any help is appreciated.
Balaji_Ram
In the sample code that you shared, I dont get the two subs called "CUSTOM_SHEETSET_PROP" and "ssdata" ? What are those methods for ?
Here is a test code mostly based on what you had posted that works ok and it adds a few custom properties to the sheetset. Maybe this helps you spot the actual error in your code.
        Public ReadOnly Property ThisDrawing() As AcadDocument
            Get
                Dim doc As Document = Application.DocumentManager.MdiActiveDocument
                Dim acadDoc As AcadDocument = TryCast(doc.AcadDocument, AcadDocument)
                Return acadDoc
            End Get
        End Property
        <CommandMethod("TestApp")> _
            Dim tblObj As AcadTable
            Dim tblPt As Object
            sheetsetCount = 0
            Loop
                Exit Sub
                Exit Sub
            End If
            End With
            SetSheetSetCustomProp()
            Exit Sub
MyError:
        End Sub
        Private Sub SetSheetSetCustomProp()
            sheetdb = ItemDb
            '' Lock Database
            LockDatabase()
            Dim i As Integer
            i = 0
            Do While i < 5
                Item = iter.Next
                cBagVal.SetFlags(PropertyFlags.CUSTOM_SHEETSET_PROP)
                cBagVal.SetValue("Test" + i.ToString())
                cBag.SetProperty("Test" + i.ToString(), cBagVal)
                cBagVal = Nothing
                i = i + 1
            Loop
            UnlockDatabase()
        End Sub
            End If
        End Sub
            End If
        End Sub
 This code inserts a few test values as custom properties and does not use the value from the table. But it should be straight forward to change that to use the values from the table.
Also the way you handle the array is a bit messy and it would help if you use a "System.Collections.Specialized.StringCollection" instead of the array.
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
