.NET
Active Contributor
0 Kudos
Post 1 of 26
VB.NET SAVEAS / eFileAccessErr
674 Views, 25 Replies
01-14-2014 11:41 AM
whenever I try to save my curret drawing as I will get this error.
I was looking here what could be the issue but no success yet.
Do you now what could be the problem?
Many thanks.
I used standard method;
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
<CommandMethod("SaveActiveDrawing")> _
Public Sub SaveActiveDrawing()
  Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
  Dim strDWGName As String = acDoc.Name
  Dim obj As Object = Application.GetSystemVariable("DWGTITLED")
  '' Check to see if the drawing has been named
  If System.Convert.ToInt16(obj) = 0 Then
      '' If the drawing is using a default name (Drawing1, Drawing2, etc)
      '' then provide a new name
      strDWGName = "c:\MyDrawing.dwg"
  End If
  '' Save the active drawing
  acDoc.Database.SaveAs(strDWGName, True, DwgVersion.Current, _
                        acDoc.Database.SecurityParameters)
End Sub
Peter,
I must admit I'm a little embarassed... In my haste to show how the ACAD api has issues I didn't address your question...  SaveAs as it turns out is much easier... :smileyhappy:
Dim newfile As String = Path.Combine(Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments), "drawing1.dwg")
dim db as Database = DocumentManager.MdiActiveDocument.Database
db.SaveAs(newfile, DwgVersion.Current)
This is all that is required to SaveAs.  I hope you find a need for savedamnyou though as it's just fun to use... :smileyhappy:
Now... let me address why you can't write to c:\test.dwg
If you're running on Windows 7 or Windows 8, then the root of C is protected and UserAccessControl (UAC) is probably affecting you.  Hence, my code above finds the users my documents folder and writes there.  If you're dead set on writing to c: then right click autocad and choose run as administrator.  Then it will let you write to c:
-Jon
Distinguished Mentor
91 Kudos
Post 2 of 26
Re: VB.NET SAVEAS / eFileAccessErr
01-14-2014 12:23 PM in reply to: xpeter88
Do you have permision to write in C:\?
Gaston Nunez
Active Contributor
0 Kudos
Post 3 of 26
01-14-2014 12:27 PM in reply to: gasty1001
Sure, I am on my laptop and there is no issue to manipulate with any files :-/
Active Contributor
0 Kudos
Post 4 of 26
01-14-2014 12:32 PM in reply to: xpeter88
This is that error;
91 Kudos
Post 5 of 26
01-14-2014 01:46 PM in reply to: xpeter88
Just try the same code, but this time saving to a folder, and see what happens. This may help:Disabling UAC
Gaston Nunez
30 Kudos
Post 6 of 26
01-15-2014 02:58 AM in reply to: xpeter88
sometimes if you do not lock the document then this type of error occurs. As you are using command method so document should be locked automatically. But you can try to lock the document in code explicitly and try the code once again.
7 Kudos
Post 7 of 26
01-15-2014 06:52 AM in reply to: xpeter88
Peter,
Yes, it happens.  We fought with the SaveAs api in Autocad for a LONG time.  The following is what we have thus far.  It's a shame that something so basic / trivial has to be such a pain.
	''' <summary>
	''' saves the current drawing
	''' </summary>
	''' <param name="db">the database / drawing</param>
	''' <remarks>We only had to write this because the autocad api is retarded</remarks>
	<Extension()>
	Public Sub SaveDamnYou(db As Database)
		Dim doc As Document = Nothing
		Try
			doc = DocumentManager.GetDocument(db)
		Catch
			'db is in batch mode
		End Try
		'If we have a document, attempt to call a quick save
		If doc IsNot Nothing Then
			If doc.IsReadOnly Then
				Throw New ROCException("Save failed. Drawing is Read-Only.")
			Else
				Try
					doc.Save()
				Catch ex As Exception
					doDBSave(db)
				End Try
			End If
		Else
		'If no document, attempt to save the database itself
		doDBSave(db)
		End If
	End Sub
	''' <summary>
	''' Attempts to save the database to itself, or logs an error if it fails
	''' </summary>
	''' <param name="db"></param>
	''' <remarks></remarks>
	Public Sub doDBSave(db As Database)
		Try
			Dim DwgFilePath As String = db.GetRealFilename
			db.SaveAs(DwgFilePath, TrueDwgVersion.Current, db.SecurityParameters)
		Catch ex As Autodesk.AutoCAD.Runtime.Exception
			LogInfo("Acad Error Status: {0}".FMe(ex.ErrorStatus))
			Throw
		End Try
	End Sub
	''' <summary>
	''' Saves the document via COM
	''' </summary>
	''' <param name="doc">document to be saved </param>
	''' <remarks>Used by the above save routine to allow a lock document to be saved, because the API is SUPER retarded</remarks>
	<Extension()>
	Public Sub Save(doc As Document)
		Dim adoc As Interop.AcadDocument = CType(doc.AcadDocument, Interop.AcadDocument)
		'adoc.Save()
		adoc.SendCommand("_QSAVE ")
	End Sub
	''' <summary>
	''' gets the real filename of the database. instead of .sv$ filenames
	''' </summary>
	''' <returns>returns the real filename</returns>
	''' <remarks>http://through-the-interface.typepad.com/through_the_interface/2008/03/getting-the-ful.html</remarks>
	<Extension()>
	Public Function GetRealFilename(db As DatabaseAs String
		Try
		Catch
			'This error indicates that there is no document object
		End Try
		'is this open in batch mode?
		If doc Is Nothing Then
			Return db.Filename
		Else
			Return doc.Name
		End If
	End Function
Active Contributor
0 Kudos
Post 8 of 26
01-16-2014 08:03 AM in reply to: gasty1001
Gaston Nunez
No this did not help.
Active Contributor
0 Kudos
Post 9 of 26
01-16-2014 08:04 AM in reply to: mzakiralam
No success as well :/ I tried to lock the document already.
Active Contributor
0 Kudos
Post 10 of 26
01-16-2014 08:08 AM in reply to: jon-p
jon-p: What references do I have to use? Some expressions are not recognized. I've got loaded AcCui, AcDbMgd, AcMgd.
Then;
Imports System
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Colors
Nothing else I do not need for code I have. But it seems that for your code I missed something.
