.NET
.NET
Valued Contributor
kcimos
Message 1 of 3 (254 Views)
vb.net routine - autocad says unkown command
254 Views, 2 Replies
03-03-2012 02:46 PM
I have no idea why autocad 2012 refuses to load this, or it is loading it but something else is causing the command to not be known.
I have no errors in visual studio & I get no errors when I netload.
I'm sure there are logic errors since I haven't been able to debug this yet (migrating it from VBA to VB.NET)
any help would be appreciated.
the start point / command is in Class2 in vbLayerGroupController
ACF & ACGen contain functions called by my routine.
While trying to figure this out, as a test, I had created a new class with a generic msgbox command within this project & it worked (I removed it now), so there is something in here that autocad doesn't like.
norman.yuan
Message 2 of 3 (242 Views)
Re: vb.net routine - autocad says unkown command
03-03-2012 06:47 PM in reply to: kcimos
In your class2.vb file, add this line after the "Imports..." instruction and before the class LayerGroupController, like this:
Imports Autodesk...
Imports .....
<Assembly: CommandClass(GetType(LayerGroupController))>
Class LayerGroupController
    <CommandMethod("LKK")>_
    Public Sub LayerGroupController()
    End Sub
EndClass
HTH
Valued Contributor
kcimos
Message 3 of 3 (237 Views)
03-03-2012 08:08 PM in reply to: norman.yuan
that worked.
what is it? why?
I don't have that in any other projects that work.
thanls.
I would have NEVER figured that out.
also, useful tip for anyone out there (maybe):
I set option strict  = ON, & a lot of errors revealed themselves.
I've been leaving it off because there always ends up being at least one thing I can't resolve, like with this program there was one late binding error (keep in mind I haven't begun to debug this yet since I haven't yet been able to enter my command in autocad to start the process):
ForEach Ent AsObjectInACF.ThisDrawing.PaperSpace
If Ent.ObjectName = "AcDbViewport"Then
