.NET
VB.NET: Inserting a file (block)
6 REPLIES 6
joshlund
7320 Views, 6 Replies
Good evening,
Does anyone have a code snippet that shows how to insert a drawing (as a block) into the current drawing? I searched this forum for a few samples and only found partial functions, too little for me to turn into a working function or even understand what I should attempt to do.
I have a drawing on my hard drive and I want to insert it into my current drawing. It seems simple enough but I'm not getting it. Any suggestions?
Josh
Windows XP SP2
VS 2005 SP1
AutoCAD Civil 3D 2009 SP2
6 REPLIES 6
in reply to: joshlund
Perhaps this will help.
Joe
    <CommandMethod("IBFF")>
_
    Public Shared Sub
InsertBlockFromFile()
        'get an
editor object
        Dim ed As Editor =
Application.DocumentManager.MdiActiveDocument.Editor
        'ask for
block name from user
        Dim
BlockNameOptions As PromptStringOptions = New PromptStringOptions("Enter block
name")
        'no spaces allowed with
block names
BlockNameOptions.AllowSpaces =
False
        'get the
input
        Dim BlockNameResult As
PromptResult = ed.GetString(BlockNameOptions)
        'check
for valid input
        If
(BlockNameResult.Status = PromptStatus.OK)
Then
            'get
the working
database
Dim dwg As Database =
ed.Document.Database
'start a
transaction
Dim ta As Transaction = dwg.TransactionManager.StartTransaction
size=2>
Try
'create temporary database to read in
block
Dim dbDwg As New
Database()
'read the file from
disk
dbDwg.ReadDwgFile("C:\Drawing2.dwg", IO.FileShare.Read, True,
'insert it into the current
database
dwg.Insert(BlockNameResult.StringResult.ToString, dbDwg,
False)
'dispose of temporary database
object
dbDwg.Dispose()
size=2>
'open the block table for
read
Dim BlockTable As BlockTable = ta.GetObject(dwg.BlockTableId,
OpenMode.ForRead)
size=2>
'see if the block table record
exists
If (BlockTable.Has(BlockNameResult.StringResult) = True)
Then
'prompt user for insertion
point
Dim PromptPointOptions As PromptPointOptions = New PromptPointOptions("Select
insertion
point")
'get user to select the insertion
point
Dim PromptPointResult As PromptPointResult =
ed.GetPoint(PromptPointOptions)
size=2>
'user selected a valid
point
If (PromptPointResult.Status = PromptStatus.OK)
Then
'fix up the point to be a Point3D
object
Dim Point3D As New Point3d(PromptPointResult.Value.X, PromptPointResult.Value.Y,
PromptPointResult.Value.Z)
size=2>
'insert the block at the insertion
point
Dim BlockRef As BlockReference = New BlockReference(Point3D,
BlockTable.Item(BlockNameResult.StringResult))
size=2>
'add block reference to the current
space
Dim CurrentSpace As BlockTableRecord = ta.GetObject(dwg.CurrentSpaceId,
OpenMode.ForWrite)
size=2>
'add the block reference to the current
space
CurrentSpace.AppendEntity(BlockRef)
size=2>
'tell the
transaction
ta.AddNewlyCreatedDBObject(BlockRef, True)
size=2>
'commit transaction to
database
ta.Commit()
size=2>
End If
size=2>
Else
MsgBox("Block " & BlockNameResult.StringResult.ToString & " does not
exists")
size=2>
End If
size=2>            Catch
ex As
Exception
MsgBox(ex.Message)
size=2>
Finally
size=2>
'always dispose of
transaction
ta.Dispose()
size=2>            End
Try
        End If
End Sub
<JoshLund> wrote in message
news:6107709@discussion.autodesk.com...
Good evening, Does anyone have a code
what I should attempt to do. I have a drawing on my hard drive and I want to
it. Any suggestions? Thanks, Josh Windows XP SP2 VS 2005 SP1 AutoCAD Civil 3D
2009 SP2
joshlund
Joe,
Let me start out by saying thanks for such an excellent example. It is well commented and easy to follow.
When I first ran the code, it threw a FileNotFound exception. Not sure where "C:\Drawing2.dwg" was coming from I changed it to the name of the block I wanted to insert. This cleared up that exception. Not sure if that was the right thing to do as I encountered another problem a short time later.
'read the file from disk
'dbDwg.ReadDwgFile("C:\Drawing2.dwg", IO.FileShare.Read, True, "")
was changed to. . .
dbDwg.ReadDwgFile(BlockNameResult.StringResult.ToString, IO.FileShare.Read, True, "")
I ran it again and the following line threw an OutOfRange exception.
dwg.Insert(BlockNameResult.StringResult.ToString, dbDwg, False)
I tried a few things to fix this but can't seem to find the answer. Some things I tried: I changed BlockNameResult.StringResult.ToString to a static string, just to see if it would work. I tried specifying the block name with a full path and without a full path, thinking the path may have been causing the outof range exception.
The class file is attached as Class1.txt. Any suggestions?
Josh
Sorry to say, but we can't call that an 'excellent' example.
Joe's code (assuming he actually wrote it, that is) converts the user's
coordinate into a Point3d. Problem is, it's
already a Point3d, making that pointless and unnecessary.
The code he posted also needlessly looks up the objectid of the
newly-inserted BlockTableRecord, when that is what is returned by the
Insert() method, whose result his code completely ignores.
So no, we can't call that an 'excellent' example.
My suggestion would be to focus on learning the language and the API. For
example, you call the 'ToString()' method on an object that is already a
string. If the object is already a string, you don't have to convert it to a
string. But it is the fact that you do not know that the object is already a
string, that suggests that you're trying to run before having learned to
walk, and that's the core problem you're faced with. No matter how good the
examples you find here are, they're not going to help you that much if you
don't understand the code, or how to modify/adapt them to your particular
situation.
If you are going to use VB.NET and the ObjectARX API, you have to learn to
use the programming language; the .NET framework, and the AutoCAD .NET API,
in that order.
The example below is in C#, but you can convert it to VB.NET using various
online translators or Reflector.
[code]
{code}
using System;
using System.Collections.Generic;
using System.Text;
using System.IO;
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
using Acad = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof( Namespace1.InsertBlockFromFileExample ))]
namespace Namespace1
public static class InsertBlockFromFileExample
[CommandMethod("XINSERT")]
public static void InsertFromFileCommand()
OpenFileDialog ofd = new OpenFileDialog();
ofd.DefaultExt = ".dwg";
ofd.Filter = "Drawing Files (*.dwg)|*.dwg";
if( ofd.ShowDialog( Acad.MainWindow ) != DialogResult.OK )
return;
Document doc = Acad.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
PromptPointOptions ppo = new PromptPointOptions( "\nInsertion
point: " );
PromptPointResult ppr = ed.GetPoint( ppo );
if( ppr.Status != PromptStatus.OK )
return;
using( Database xDb = new Database( false, true ) )
xDb.ReadDwgFile( ofd.FileName, FileShare.Read, true, null );
using( Transaction tr =
doc.TransactionManager.StartTransaction() )
string name =
SymbolUtilityServices.GetBlockNameFromInsertPathName( ofd.FileName );
ObjectId id = db.Insert( name, xDb, true );
if( id.IsNull )
ed.WriteMessage( "\nFailed to insert block" );
return;
BlockTableRecord currSpace = tr.GetObject( db.CurrentSpaceId,
OpenMode.ForWrite ) as BlockTableRecord;
BlockReference insert = new BlockReference( ppr.Value, id );
currSpace.AppendEntity( insert );
insert.SetDatabaseDefaults();
tr.AddNewlyCreatedDBObject( insert, true );
tr.Commit();
{code}
[/code]
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:6108224@discussion.autodesk.com...
Joe, Let me start out by saying thanks for such an excellent example. It is
well commented and easy to follow. When I first ran the code, it threw a
another problem a short time later. 'read the file from disk
'dbDwg.ReadDwgFile("C:\Drawing2.dwg", IO.FileShare.Read, True, "") was
changed to. . . dbDwg.ReadDwgFile(BlockNameResult.StringResult.ToString,
IO.FileShare.Read, True, "") I ran it again and the following line threw an
OutOfRange exception. dwg.Insert(BlockNameResult.StringResult.ToString,
dbDwg, False) I tried a few things to fix this but can't seem to find the
have been causing the outof range exception. The class file is attached as
Class1.txt. Any suggestions? Thanks, Josh
Thank you, Tony.
This code works really great, as allways. I hope you don't mind that I
changed the code a little bit that it works with annotative blocks, too.
Don't forget to set a reference to acmgdinternal.
[code]
{code}
using System;
using System.Text;
using System.IO;
using Autodesk.AutoCAD.Internal;
[assembly: CommandClass(typeof( RSNNAcadApp.Test.InsertBlock_Tanzillo ))]
namespace RSNNAcadApp.Test
class InsertBlock_Tanzillo
if (ofd.ShowDialog(Acad.MainWindow) != DialogResult.OK)
return;
PromptPointOptions ppo = new PromptPointOptions("\nEinsetzpunkt:
PromptPointResult ppr = ed.GetPoint(ppo);
if (ppr.Status != PromptStatus.OK)
return;
using (Database xDb = new Database(false, true))
xDb.ReadDwgFile(ofd.FileName, FileShare.Read, true, null);
using (Transaction tr =
doc.TransactionManager.StartTransaction())
string name =
SymbolUtilityServices.GetBlockNameFromInsertPathName(ofd.FileName);
ObjectId id = db.Insert(name, xDb, true);
if (id.IsNull)
ed.WriteMessage("\nFailed to insert block");
return;
//for inserting an annotative dwg
if (xDb.AnnotativeDwg)
using (BlockTableRecord btrAnnotative =
(BlockTableRecord)tr.GetObject(id, OpenMode.ForWrite))
btrAnnotative.Annotative =
AnnotativeStates.True;
tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
BlockReference insert = new BlockReference(ppr.Value,
id);
currSpace.AppendEntity(insert);
//Attach Current Annotation-Scale.
//If you don't add the content, the block and the
following attribute will not inserted correct.
ObjectContextManager ocm = db.ObjectContextManager;
ObjectContextCollection occ =
ocm.GetContextCollection("ACDB_ANNOTATIONSCALES");
ObjectContexts.AddContext(insert,
occ.CurrentContext);
tr.AddNewlyCreatedDBObject(insert, true);
tr.Commit();
{code}
[/code]
Glad it worked for you, and thanks for posting
your enhancement. I'm sure others might find it useful.
"Roland Feletic" wrote in message
news:6108849@discussion.autodesk.com...
Thank you, Tony.
[code]
{code}
using System;
using System.Text;
using System.IO;
return;
return;
string name =
if (id.IsNull)
return;
id);
tr.Commit();
{code}
[/code]
eckdahlrd
Tony, I appreciate you posting this code and providing the solution. I found it to be helpful to me, and really didn't have much pain in converting it to vb.net and getting it to fit into my existing class.
I'm hoping to be able to tweak it so that rather than using the file dialog, that it would use a specific file that is identified as part of another sub in an "IF....THEN" statement. I don't know if that's possible, but I guess I'll find out. 😉
Thanks again. Very helpful.
”Boost
