.NET
VB.NET Image Bounding Box
2 REPLIES 2
ced_abitat
588 Views, 2 Replies
Hi all,
  I need to get the bounding box of a image loaded on AutoCAD in VB.NET.
Can you help me?
Regards
Matteo
2 REPLIES 2
_gile
in reply to: ced_abitat
If you're talking about a raster image (RasterImage .NET type), it inherits from Entity type which has GeometricExtents property (Extents3d).
Gilles Chanteau
GileCAD
GitHub
SENL1362
This might help you to get what you need.
        [CommandMethod("TestRasterInfo")]
        public void TestRasterInfo()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    ed.WriteMessage("\n Start TestRasterInfo");
                    TypedValue[] rasterItem = new TypedValue[] { new TypedValue(0, "IMAGE") };
                    SelectionFilter rasterSelecFilter = new SelectionFilter(rasterItem);
                    PromptSelectionResult selectResult = ed.SelectAll(rasterSelecFilter);
                    var usedImageDefs = new Dictionary<ObjectId, RasterImage>();
                    if (selectResult.Status == PromptStatus.OK)
                        SelectionSet rasterSelSet = selectResult.Value;
                        ed.WriteMessage("\n Number of raster images in use: {0}", rasterSelSet.Count);
                        for (int i = 0; i < rasterSelSet.Count; i++)
                            RasterImage rasterImage;
                            rasterImage = (RasterImage)tr.GetObject(rasterSelSet[i].ObjectId, OpenMode.ForRead);
                            BlockTableRecord rasterBtr = (BlockTableRecord)tr.GetObject(rasterImage.BlockId, OpenMode.ForRead);
                            RasterImageDef rasterDef = (RasterImageDef)tr.GetObject(rasterImage.ImageDefId, OpenMode.ForRead);
                            usedImageDefs[rasterImage.ImageDefId] = rasterImage;
                            ed.WriteMessage("\n   Name: {0}", rasterImage.Name);
                            if (rasterBtr.IsLayout)
                                Layout layout = (Layout)tr.GetObject(rasterBtr.LayoutId, OpenMode.ForRead);
                                ed.WriteMessage("\n     Layout: {0}", layout.LayoutName);
                            ed.WriteMessage("\n     Raster image definition: {0}", rasterDef.ActiveFileName);
                    ObjectId imageDictId = RasterImageDef.GetImageDictionary(db);
                    if (!imageDictId.IsNull)
                        DBDictionary imageDict = (DBDictionary)tr.GetObject(imageDictId, OpenMode.ForRead);
                        ed.WriteMessage("\n Raster Definitions:");
                        foreach (DBDictionaryEntry imageDefEntry in imageDict)
                            ed.WriteMessage("\n   Name: {0}", imageDefEntry.Key);
                            RasterImageDef imageDef = (RasterImageDef)tr.GetObject(imageDefEntry.Value, OpenMode.ForWrite);
                            ed.WriteMessage("\n     Type: {0}", imageDef.FileType);
                            ed.WriteMessage("\n     Embedded: {0}", imageDef.IsEmbedded ? "Yes" : "No");
                            ed.WriteMessage("\n     Loaded:{0}", imageDef.IsLoaded ? "Yes" : "No");
                            ed.WriteMessage("\n     InUse: {0}", usedImageDefs.ContainsKey(imageDef.ObjectId) ? "Yes" : "No");
                            ed.WriteMessage("\n     Proxy: {0}", imageDef.IsAProxy ? "Yes" : "No");
                            ed.WriteMessage("\n     Size: {0}, {1}", imageDef.Size.X, imageDef.Size.Y);
                            ed.WriteMessage("\n     Units: {0}", imageDef.ResolutionUnits.ToString());
                            ed.WriteMessage("\n     Saved Path: {0}", imageDef.SourceFileName);
                            ed.WriteMessage("\n     Found Path: {0}", imageDef.ActiveFileName);
                    ed.WriteMessage("\n Block definitions:");
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    foreach (ObjectId btrId in bt)
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(btrId, OpenMode.ForWrite);
                        ed.WriteMessage("\n     Block: {0}", btr.Name);
                    tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage("\n {0}", ex.Message);
”Boost
