Hello.
I am trying to convert some vba codes into vb.net . using vb express 2010 . The first problem I faced is the controls does not show on form. I have just a label and command button on form.
I used.
Frm.showdialog()
This is a Dll not exe.
I
the form show blank no contorl on it.
Could some body please upload a simple example for this. I am not very familiar with programming terminology . But I understand codes.
Please visit the site below might be helpful for you.
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html
Prajith.
You're asking others here to guess what is
wrong with your code, without showing it.
I doubt anyone here is interested in playing
guessing games. If you want to post your
code or the parts needed to reproduce the
problem you have, then you can get help.
1. Right click in solution explorer in the context menu under ADD select Windows Form
2. Name it FormTest
3. Drag a label button whatever on it
4. In your command method or where ever you are are calling it from add
Dim frm As New FormTest
frm.ShowDialog()
