.NET
VB.NET: Deleting Custom Properties using SheetSet Manager API in VB.NET
2 REPLIES 2
jshimkus
6330 Views, 2 Replies
I currently use code similar to Lee Ambrosius's 2009 AU handout that shows how to set/create custom properties.  It can be seen here http://adndevblog.typepad.com/autocad/2013/09/using-sheetset-manager-api-in-vbnet.html, search for the header 'Adding Sheet Set and Sheet Properties'.
I have now accumulated numerous unused custom properties in my sheet set.  I haven't been able to find a way to delete these additional custom properties.
Because I use multiple subsets with multiple sheets for printing, I would rather not have to go through all the sheets, store all the custom properties I need, destroy all the existing custom properties, and then re-create just the ones I need.
Any suggestions on how to delete individual custom properties would be helpful.
MEP 2012 with VB.NET
2 REPLIES 2
Balaji_Ram
in reply to: jshimkus
Hi John,
Can you please try using "IAcSmCustomPropertyBag.SetProperty" and pass a null custom property value ?
Here is a sample code to remove a few custom properties
        sheetSetMgr = New AcSmSheetSetMgr
        Dim iterDb As IAcSmEnumDatabase
        iterDb = sheetSetMgr.GetDatabaseEnumerator
        Dim ItemDb As IAcSmPersist
        ItemDb = iterDb.Next
        sheetdb = ItemDb
        LockDatabase()
        Dim cBag As IAcSmCustomPropertyBag
        cBag = sheetdb.GetSheetSet().GetCustomPropertyBag()
        Dim enumeratorProperty As IAcSmEnumProperty
        enumeratorProperty = cBag.GetPropertyEnumerator()
        enumeratorProperty.Reset()
        Dim name As String = ""
        Dim customPropertyValue As AcSmCustomPropertyValue = Nothing
        enumeratorProperty.Next(name, customPropertyValue)
        Dim customPropNames As System.Collections.Specialized.StringCollection
        customPropNames = New System.Collections.Specialized.StringCollection
        customPropNames.Add("Test3")
        customPropNames.Add("Test6")
        Do While Not customPropertyValue Is Nothing
            If customPropertyValue.GetFlags() = PropertyFlags.CUSTOM_SHEETSET_PROP And customPropNames.Contains(name) Then
                cBag.SetProperty(name, Nothing)
        Loop
        UnlockDatabase()
Balaji
Developer Technical Services
Autodesk Developer Network
jshimkus
in reply to: Balaji_Ram
Using the statement 'cBag.SetProperty(name, Nothing)' did the trick.
Thank You
”Boost
