.NET
vb.net COM late binding setting ActiveUSC gives an error
1 REPLY 1
691 Views, 1 Reply
I'm trying to set the ActiveUCS, but when i do i get an error
System.Runtime.InteropServices.COMException = {"Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))"}
Autocad 2012, VB.net, i use late binding. doc is of type IAcadDocument
Dim ucs As Object = Nothing
            Dim origin(2) As Double
            If (doc.GetVariable("UCSNAME") = String.Empty) Then
                'No UCS found, make one
                Dim ucsorg As Object = doc.GetVariable("UCSORG")
                Dim ucsx As Object = doc.Utility.TranslateCoordinates(doc.GetVariable("UCSXDIR"), 1, 0, 0)
                Dim ucsy As Object = doc.Utility.TranslateCoordinates(doc.GetVariable("UCSYDIR"), 1, 0, 0)
                ucs = doc.UserCoordinateSystems.Add(ucsorg, ucsx, ucsy, "OriginalUCS")
            Else
                ucs = doc.ActiveUCS
            End If
            'Set the origin
            origin(0) = point.X
            origin(1) = point.Y
            origin(2) = point.Z
            ucs.origin = origin
            doc.ActiveUCS = ucs
1 REPLY 1
Balaji_Ram
You can try setting it this way :
            Dim params() As Object = {ucs}
            doc.GetType().InvokeMember("ActiveUCS", Reflection.BindingFlags.SetProperty, Nothing, doc, params, Nothing, Nothing, Nothing)
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
