.NET
Valued Contributor
CommCorp
Message 1 of 3 (534 Views)
VB.NET: autocad tables and table breaks
534 Views, 2 Replies
09-19-2013 11:50 AM
Through vb.net, I've added a brand new table to the drawing database.  I enable table breaking and set the break height to force the table to flow to the right.  I am now trying to determine how many additional 'tables' are being created while still in vb.net.  For example, I have a table with an initial height of 30".  If I set the setbreakheight = 10" and turn BreakEnabled = True.  How can I determine with vb.net that there are now 3 - 10" tables.
I've tried using the mytable.bounds and mytable.geometricextents to calculate the 'table' quantity, but that information does not always update once a transaction is complete and so far has been unreliable.
MEP 2012 with VB.NET
Thanks.
Hi John,
Have you tried using the "table.RecomputeTableBlock(True)" to update the geometric extents ?
ADN Support Specialist
Balaji_Ram
Message 2 of 3 (493 Views)
Re: VB.NET: autocad tables and table breaks
09-23-2013 05:36 AM in reply to: CommCorp
Hi John,
Balaji
Developer Technical Services
Autodesk Developer Network
Valued Contributor
CommCorp
Message 3 of 3 (467 Views)
09-24-2013 05:06 AM in reply to: Balaji_Ram
The .recomputetableblock(true) did the trick.  I can now determine how many 'tables' get added!!
