.NET
vb.net and c# code in same project?
4 REPLIES 4
561 Views, 4 Replies
As I understand it, each project in VS2005 must be of the same language which means each assembly must be in the same
language.
Is that right? or can I somehow make one class in vb.net and another in c# within the same project.
Hold down the laughter, I know this is a rookie question, but I have converted all code to vb.net so far and its getting
old, I'd like to be able to use both syntaxes within a project.
thx
James Maeding
Civil Engineer and Programmer
jmaeding - athunsaker - com
4 REPLIES 4
James ,
You can't mix code in a project ..
,, but 'cause each assembly is compatible at the IL level, you CAN reference
a DLL created with a different language into your project. Nominating the
same namespace for both assemblies will make that process a little easier
too.
regards
/// kwb
"James Maeding" wrote in message
news:5425038@discussion.autodesk.com...
language.
thx
James Maeding
Chumplybum
this is what i use to convert code to vb.net
http://www.developerfusion.co.uk/utilities/convertcsharptovb.aspx
You can mix VB.NET and C# code in the same assembly (as of .NET 2.0), there
just isn't any support for doing so in the Visual Studio 2005 IDE.
Dan
"Kerry Brown" wrote in message
news:5425235@discussion.autodesk.com...
James ,
too.
regards
/// kwb
language.
thx
James Maeding
you know, I always thought there would be more people doing vb.net than c#, but I am finding the opposite.
I am guessing this is because the people that know the ObjectARX side of things are C++ people, so the examples of using
.net are mostly c#.
I do like the compactness of the c# syntax, I kind of wish there was only c# or vb.net, not both so the examples were
not split between the two.
Mark Dubbelaar <>
James Maeding
”Boost
