.NET
VB.NET - ADT: Accessing a style object (AecObject) by style name (String)?
9 REPLIES 9
Message 1 of 10
602 Views, 9 Replies
in VBA it's easy:
(using AEC Architectural Object Library (COM))
Dim AecDoc As New AecArchBaseDocument
AecDoc.Init ThisDrawing
Dim MyWallStyleName as String
MyWallStyleName = "Wall-A"
Dim MyStyleObject as AecObject
Set MyStyleObject = AecDoc.WallStyles.Item(MyWallStyleName)
but there's no 'Item' in VB.NET (that I can see...)
So, in VB.NET, I've tried:
(using AecArchMgd.dll)
Autodesk.Aec.Arch.DatabaseServices.DictionaryWallStyle.GetAt(MyWallStyleName)
thinking that this would work?
But I get an error list message:
'Reference to a non-shared member requires an object reference.'
what does this mean?
9 REPLIES 9
Message 2 of 10
Hey Corey,
The error message is telling you that the GetAt() method is an instance
method, not a shared method. You need an instance of a DictionaryWallStyle
object.
Bobby C. Jones
"Corey A. Layton" wrote in message
news:5196855@discussion.autodesk.com...
in VBA it's easy:
Message 3 of 10
You need an instance of your class before you can use it's
methods and fields that are not defined as 'Shared'
If you define your feilds as Share you do not need to instantiate
their class before using them, you can just call them directly with
out using the New keyword first.
in VBA it's easy:
Message 4 of 10
Bobby & Paul,
thanks for trying to help.
but I'm still lost.
Do either of you know of a resource that gives an example of accessing AEC
styles using AecArchMgd.dll? (complete code?)
Message 5 of 10
Have you tried the samples the came with
ADT?
news:5197118@discussion.autodesk.com...
Bobby & Paul,
but I'm still lost.
Message 6 of 10
Corey,
Look in the sample folder under your ADT folder. Do you have the aecmgddbg
app that Jim awe created?
Bobby C. Jones
Bobby & Paul,
but I'm still lost.
Message 7 of 10
Bobby C. Jones wrote:
> Corey,
yeah, I'm in there now...
>Do you have the
> aecmgddbg app that Jim awe created?
no. what's that all about?
Message 8 of 10
>>Corey,
>>Do you have the
Corey,
The AecHardwiredStylesMgd sample (ADT2007) may be helpful...
Brian Winterscheidt
LWPB Architecture
Oklahoma City, Oklahoma
Message 9 of 10
Jim posted some useful samples. Search the ng for threads authored by Jim.
Ed
Message 10 of 10
See "MgdDbg & MgdDbgAec" in CF.
Bobby C. Jones
news:5197390@discussion.autodesk.com...
> Corey,
>Do you have the
”Boost
