.NET
[VB.NET] AcedPostCommand 2013
2 REPLIES 2
AdriDicri
1419 Views, 2 Replies
Hello everyone !
I'm trying to migrate my autocad2012 addon to 2013, but i've got a problem with the AcedPostCommand.
Here's my code in 2012 :
 Declare Auto Function acedPostCommand Lib "acad.exe" _
      Alias "?acedPostCommand@@YAHPB_W@Z" _
      (ByVal strExpr As String) As Integer
but in the 2013 it doesn't work. Autocad says :
"System.EntryPointNotFoundException: Impossible de trouver le point d'entrée '?acedPostCommand@@YAHPB_W@Z' dans la DLL 'acad.exe'."
Can someone help me?
Thanks !
Adri DiCri
ps : sorry for my english, french is my mother tongue
2 REPLIES 2
Try to change "acad.exe" with "accore.dll" in your's declaration.
Also for AutoCAD x64 Alias is "?acedPostCommand@@YAHPEB_W@Z" and for AutoCAD x86 Alias is "?acedPostCommand@@YAHPB_W@Z"
Facebook | Twitter | LinkedIn
Expert Elite Member
Thanks !
”Boost
