hi all
this is my first program in vb.net and i'm so happy to do it
but i have a little problem
i made start action with start external program = c:\program files\AutoCAD 2010\acad.exe like picture
so when i VB.net i have this message
so what can i do to solve this problem which to error when i run my dll using netload from autocad directly
Solved by Alexander.Rivilis. Go to Solution.
Instead of Debug->Start Debugging try Debug->Attach to Process... and select acad.axe
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Attach to Running Processes with the Visual Studio Debugger:
Do you happen to have Nero CD/DVD burning application installed? Anyway, if you searched the Internet for "debugger detected - please close it down and restart", you would have found tons of links. Some of them may help you:
http://www.indigorose.com/forums/threads/2357-Debugger-detected-Please-close-it-down-and-restart!
http://www.portraitprofessional.com/forum/showthread.php?tid=77
http://www.pcreview.co.uk/forums/debugger-bugging-me-t319053.html
http://forum.videohelp.com/threads/332379-Protection-error-Debugger-Detected
Norman Yuan
It was helped to you?
if you are using VS2012 each new project is set to use Framework 4 (or 4.5). If you need to develop based on AutoCAD 2010 your project has to be set to Framework 3.5.
What Framework is set to your VS-project?
- alfred -
@Amremad_world wrote:
doesn't work
What doesn't work? You can not attach to AutoCAD? You received any other error?
sorry for late.
iam already using .net framework 3.5 ,
and when i use attach to process , nothing happen , and my commmand desn't define . i need to fix the message when i run my program , i think attach to process not useful for me.
i tried my code in two computers
1- windows xp with cad2010
2- windows 7 with cad2010
and this message also apear
what can i do for this .
Did you try the Norman suggestion about Nero products in the test machines? It seems it's the more probably cause of that message. I also found this: http://www.planetdvd.net/board/index.php/mv/tree/11011/0/
Gaston Nunez
Hi, Gaston! amremad_world solved his problem. It was associated with the violation of the rules of this forum, for which he apologized.
