.NET
VB.NET 2005 Interactive Debugging/Editing Limitations
1 REPLY 1
276 Views, 1 Reply
I'm trying to pin down when VB.NET can/can't do debugging/editing. It
seems as long as the Active Configuration is set to Debug I can set
breakpoints, walk through, set watches, etc.
However the next level is what I'm curious about. When the debug
external program is 32bit AutoCAD, I can stop the execution and actually
change the code while its executing as long as its 'top level' code.
Whenever the code steps into subs/functions in another .VB file (perhaps
its in a referenced module), I can't seem to edit there. I also can't
seem to stop and edit AT ALL in 64bit AutoCAD.
Are there any documented procedures on how/when this is supposed to
work? Anyone having similar experiences?
Thanks in advance,
Terry
1 REPLY 1
Okay I've found at least a partial answer to my own question in case
anyone is interested. If I'm not mistaken, code in a *linked* file
cannot be changed during the debugging process whereas code in a normal
file can.
Nothing like being able to edit the code while debugging. 🙂
Terry
”Boost
