There is a undocumented command -DWGUNITS in AutoCAD that does settings not done by the commands UNITS or INSUNITS. The settings of this command influence the scaling of inserted blocks. As far as I understand the command -DWGUNITS has its origin in the Land Development Desktop.
Does someone know which variables I have to use to do the same settings as -DWGUNITS?
I prefer code in VB.NET but C# is also OK.
Frank Lenoir
i got the same question: how to set the drawing units in .net ?
All the variables (INSUNITS LUNIT etc.) wont change the dwg unit.
My problem is: etransmit messes up the drawing units while exporting (german aca 2011 and 2012). so one way is to reset the unit to meter is using an autolisp script which opens every drawing in autocad. works nice but it is very slow for a huge amount of drawings. i would like to fix the dwg unit via c#.net.
is there any possibility to set the drawing unit in .net?
regards,
max
You can start the _UNITS command, within the dialog place the mouse cursor over the fields to change and you get the info what sysvar is used behind the fields - or other version: when the dialog is open press <F1> and you see in the help what field stands for what sysvar.
And -DWGUNITS does handle the same variables like _UNITS - except the setting for "do rescale when inserting" (whatever vocables are used for this question). For that I don't know a sysvar, sorry!
Yes, you can, most sysvars are accessible direct in the AutoCAD database properties, an example:
Dim tAcadDoc as Autodesk.AutoCAD.ApplicationServices.Document tAcadDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument tAcadDoc.Database.Unitmode = 1
HTH, - alfred -
am I missing something? I cant find a var for the drawing unit. Neither in the dxf code table nor in the autocad user documentation. i even tried the F1/mouseover in dwgunits, but i didnt find the drawing units var. i can find all the others like LUPREC and LUNITS but not one controling the drawing units (Meter etc). I binged and googled it - most answers pointed to INSUNITS (which is not the drawing unit) and to "run -dwgunits manually".
regards,
max
does >>>this<<< help?
- alfred -
in theory yes, but my drawing is already scaled correctly. iam etransmitting a dwg, drawn in meters. after etransmitting dwgunits says the file is in millimeters. the scale didnt change, so iam setting back dwgunits to meters without rescaling.
so i could basically leave the units with millimeters and just ignore it. but if i am using the file as a reference later on in aca i get a real mess if some drawings are set to mm and others to meters - because the files shouldnt be rescaled and the dims are also showing useless information. any idea?
regards,
max
Just for info for me, that I can try to reproduce:
And you tried a workflow like this (to compare we do the same):
I have tried it with AutoCAD 2012 SP1 German ... I get 6/Meters as the result.
- alfred -
iam using AutoCad Architecture 2011 and 2012 (GER) with both the latest ServicePacks and updates.
and yes to the procedure you described:
set INSUNITS to 6 (look to dialog _UNITS ==> there are "Meters" now defined)
saved the drawing
started command _ETRANSMIT
closed the current drawing
opened the DWG file from the ZIP that was created by _ETRANSMIT
now INSUNITS is set to 4
i can set INSUNITS back to 6 by lisp or c#.net - the problem is the DWGUNITS still tells me drawing units are "millimeters". i wouldnt care much about it, but my client does.
so right now i am setting the drawing back to Meters via DWGUNITS in a lisp routine. but thats just to slow for 500 dwgs.
regards,
max
Hi, grüß Dich,
Sorry, then I'm the wrong one to try to reproduce it, because I have no ACA installed, sorry!
OK, and now knowing that ACA is working there may be additional sysvars or dialogs for setting units that are ACA-special ... or does the ETRANSMIT-dialog have some options to set that? (With AutoCAD 2012 I don't have a chance to modify units).
I have tried now do that wit Civil3D (which uses the same AEC-base-classes) and I don't have the problem with standard units and Civil3D-units.
I would suggest to ask >>>this forum for ACA<<< may be it's a known defect in ACA?.
Good luck, - alfred -
What about sysvars INSUNITSDEFSOURCE and INSUNITSDEFTARGET ?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
For AutoCAD MAP(2008), see the AECDWGSETUP and -DWGUNITS commands
MEASUREMENT= 1
insunits=0
insunitsdefsource=0
insunitsdeftarget=0
ANNOTATIVEDWG=0
Other commands related
-dwgunits/-aecdwgunits
-EXPORTTOAUTOCAD
VBA code
for each blk ::Units =acInsertUnitsMillimeters
Change dxf code 70 from 1 to 0 in the dictionary AEC_Vars_Dwg_Setup.
(command "-DwgUnits" "3" "" "" "No" "No")
(defun set_dwgunits_to_no ( / dictionary_data_list)
(setq dictionary_data_list
(entget
(cdr
(assoc
350
(dictsearch (namedobjdict) "AEC_VARS")
(entmod
(subst
(cons 70 0)
(assoc 70 dictionary_data_list)
(princ)
Can someone give a translation of this code in VB or C#?
(defun set_dwgunits_to_no ( / dictionary_data_list) (setq dictionary_data_list (entget (cdr (assoc 350 (dictsearch (namedobjdict) "AEC_VARS") ) ) ) ) (entmod (subst (cons 70 0) (assoc 70 dictionary_data_list) dictionary_data_list ) ) (princ) )
@Frank: Thank you for your time.
@Alexander: INSUNITSDEFSOURCE and INSUNITSDEFTARGET are not affecting the Units in DWGUNITS and UNITS.
@FritsA4: AECDWGSETUP and DWGUNITS are working for a opened drawing. i am looking for an option to change the value in the drawing database. i only want to load the database because of performance issues.
as i mentioned before running a lisp routine which opens every drawing is not a solution for 500 dwgs.
If i change my Drawing Unit from mm to Meter nothing changes in the dxf section you mentioned:
(entget (cdr (assoc 350 (dictsearch (namedobjdict) "AEC_VARS"))))
So does anyone know where the Value is stored to set the Units in DWGUNITS/AECDWGSETUP/UNITS to Meters/Millimeters etc?
Thank you,
regards,
max
Hi Frank,
You wanted to get a translation from the LISP to VB.NET, what should I say, the codesippet you showed today morning does nothing on my pc/my Civil3D. However I could imagine what it should do: list all variables within a dictionary.
Look to my code, it takes the NOD, looks for a "AEC_VARS" item, goes through the collection of subobjects and list all the properties (name, type, value) from them. The output to a messagebox is quite ill because theres not enough place to show all properties from all records, you could change it to whatever you want, write a file or do just a debug-breakpoint and view it.
What you can see that for me in Civil3D I find a var "LinearUnit" within the item "AEC_VARS_DWG_SETUP", so my hope is you see it in your ACA also and at least you can modify it.
<Autodesk.AutoCAD.Runtime.CommandMethod("ADESK_listAecVars")> _ Public Shared Sub ADESK_getCivilUnits() Dim tAcadDoc As Document = Application.DocumentManager.MdiActiveDocument Dim tAcadDocLock As DocumentLock = Nothing Dim tTrAct As Transaction = Nothing Dim tListAllVarsStr As String = "" Try tAcadDoc = Application.DocumentManager.MdiActiveDocument tTrAct = tAcadDoc.TransactionManager.StartTransaction Dim tNOD As DBDictionary = CType(tTrAct.GetObject(tAcadDoc.Database.NamedObjectsDictionaryId, OpenMode.ForRead), DBDictionary) If tNOD.Contains("AEC_VARS") Then Dim tObjID As ObjectId = CType(tNOD.Item("AEC_VARS"), ObjectId) If (tObjID.IsValid) AndAlso (Not tObjID.IsErased) Then Dim tDBObj As DBDictionary = CType(tTrAct.GetObject(tObjID, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead), DBDictionary) If tDBObj.Count > 0 Then Dim tEnum As DbDictionaryEnumerator = tDBObj.GetEnumerator Do While tEnum.MoveNext tListAllVarsStr &= "DbDict: " & tEnum.Key & vbNewLine Dim tSubObj As DBObject = tTrAct.GetObject(tEnum.Value, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead) tListAllVarsStr &= listProperties(tSubObj) tListAllVarsStr &= vbNewLine Loop End If Debug.Print("") End If End If Call MsgBox(tListAllVarsStr) Catch ex As Exception MsgBox("Error occured" & vbNewLine & ex.Message) Finally If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing If tAcadDocLock IsNot Nothing Then tAcadDocLock.Dispose() : tAcadDocLock = Nothing End Try End Sub ''' <summary>listProperties does a MINIMAL listing of the property-values of an object ''' 'it does not evaluate any arrays, enumerations, subobjects, ... ''' </summary> ''' <param name="Obj"></param> ''' <returns>a string listing prop-name, prop-type, prop-value</returns> ''' <remarks></remarks> Private Shared Function listProperties(ByVal Obj As Object) As String Dim tRetVal As String = "" If Obj IsNot Nothing Then Dim tPropDefs() As PropertyInfo = Obj.GetType.GetProperties() For Each tPropDef As PropertyInfo In tPropDefs Dim tValStr As String = vbTab & tPropDef.Name & vbTab & "(" & tPropDef.PropertyType.FullName & "):" & vbTab Try Dim tVal As Object = tPropDef.GetValue(Obj, Nothing) If tVal IsNot Nothing Then tValStr &= tVal.ToString Else tValStr &= "<nothing>" End If Catch ex As Exception tValStr &= "<error evaluating>" End Try tRetVal &= tValStr & vbNewLine Next End If Return tRetVal End Function
HTH, - alfred -
Hi Alfred,
Thanks very much. I think this will set me on the right track.
Regards, Frank
dear all,
i found the drawin unit in the following variable in the drawings aec database:
using AECAPP = Autodesk.Aec.ApplicationServices;
public void testunit()
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Database db = HostApplicationServices.WorkingDatabase;
Transaction tr = db.TransactionManager.StartTransaction();
using (tr)
ObjectId objID = AECAPP.DrawingSetupVariables.GetInstance(db,false);
AECAPP.DrawingSetupVariables dsv = (AECAPP.DrawingSetupVariables)tr.GetObject(objID, OpenMode.ForWrite);
String from = dsv.LinearUnit.ToString();
String to = Autodesk.Aec.BuiltInUnit.Meter.ToString();
ed.WriteMessage("{0} to {1}.",from, to);
dsv.LinearUnit = Autodesk.Aec.BuiltInUnit.Meter;
tr.Commit();
