.NET
Utilizing Autocad Macros in .NET
1 REPLY 1
449 Views, 1 Reply
I am using VB.NET & want to utilize Autocad macros in Programming.
I want to select the detail views for dimensiong and detailing in the drawings that are generated from Autocad with VB.NET.
Pls suggest.
Regards
Deepak
1 REPLY 1
Balaji_Ram
Hi Deepak,
Can you please share some screenshots ?
Are you referring to the detail view in the model documentation feature of AutoCAD 2013 ?
We can then see if that is possible with the AutoCAD .Net API.
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
