Hi. Sorry to say this, but...
Rules and guidelines that govern most serious software
development, preclude licensing third party code that
does not include source, unless if is from an established,
reputable business entity that has been in business for
some amount of time; and it provides some significant
functionality that could not be arrived at via programming,
without significant expense.
Another major problem with your code, is that it appears
to be an 'alternative' API/object model, where the main
purpose is to create a dependence on itself, that is for the
most part, illegitmate.
In other words, I and many others don't need your code to
persist data in AutoCAD drawings. The API's we have can
be used to do that, and of course, we can also take the
same approach, and make the code we write that does the
same thingreusable, and most importantly, we have and
own the source.
Allowing one's self to be at your mercy, and to become
dependent on you, who can vanish into thin air at any
time, just as quickly as you appeared, is nothing short
of foolish.
If your code or library did something significant, that
most reasonably competent programmers could not do
on their own with some programming, and you were
an established, reputable business that had an existing
customer base; or demonstrated that you were making
a major investment in becoming that, then and only
then, can one give serious consideration to licensing
anything from you.
However, in absense of those prerequisites, my advice
to you, would be to not waste too much of your time
developing something if you're doing that mainly for the
purpose of licensing it to others, without also providing
them with the source code, or at least, with the option
to purchase it for a fee.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:5053906@discussion.autodesk.com...
I'm developing this library for fun and for sale too. I'm going to add some more functionality.
Could you write me what kind of license do you ask about at acmx@chat.ru ?
