I have an issue which is reproducible in AutoCAD 2014 (have not tested in other versions). When the drawing search feature (click Icon Button at top left, use search text box at top) is executed when my progrmatically created Ribbon Tab is in place, AutoCAD crashes with the following error:
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.AutoCAD.Internal.Windows.SearchUtil.ContainAnyKeywordInTooltip(RibbonItem item, List`1 searchRecords)
at Autodesk.AutoCAD.Internal.Windows.SearchUtil.SearchTextFromItem(RibbonItem item, SearchRecords searchRecords)
at Autodesk.AutoCAD.Internal.Windows.SearchUtil.SearchCommandItem(RibbonCommandItem cmdItem, SearchRecords searchRecords, List`1 bestMatches, List`1 normalMatches, List`1 relativeMatches, String itemPath, String groupName)
at Autodesk.AutoCAD.Internal.Windows.SearchUtil.SearchItems(RibbonItemCollection items, SearchRecords searchRecords, ISearchResults feedback, List`1 bestMatches, List`1 normalMatches, List`1 relativeMatches, String itemPath, String groupName)
at Autodesk.AutoCAD.Internal.Windows.SearchContent.SearchInRibbon(SearchRecords searchRecords, ISearchResults feedback, List`1 bestMatches, List`1 normalMatches, List`1 relativeMatches)
at Autodesk.AutoCAD.Internal.Windows.SearchContent.Search(String searchText, ISearchResults feedback)
at Autodesk.Private.Windows.SearchWorker.Search()
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
Looking at the top of the call stack, I am left wondering if the problem is that I have set a tooltip to null. Why this should cause AutoCAD to completely crash is beyond me. A simple check for null would prevent the error. Maybe I don't comprehend something going on here.
Here is the source for a class responsible for creating the ribbon tab for my plugin and populating it with controls. Some of the code dynamically creates ribbon items based on data stored in a database, so it is not possible to provide working code, unfortunately.
I've tried setting the tooltips of some items to string.empty instead of null where i thought they might be null. But I'm wondering if this is even the problem at all. Any insights would be much appreciated.
Public Class ACADRibbonFactory Public Shared Function BuildACADRibbon(ByVal RibbonData As DataSet) As ACADRibbonManager If RibbonData Is Nothing Then Throw New ArgumentNullException("RibbonData") Dim ribbonTabs As New List(Of ACADRibbonTab) Dim manager As New ACADRibbonManager(ribbonTabs, RibbonData.Tables("AutoCAD_Ribbon_Panel_Conveyor_Type")) For Each tabRow As DataRow In RibbonData.Tables("AutoCAD_Ribbon_Tab").Select("", "Position") Dim acadTabObject As New RibbonTab() acadTabObject.Title = tabRow("Title").ToString() acadTabObject.Tag = tabRow("ID").ToString() acadTabObject.Id = tabRow("ID").ToString() Dim tab As New ACADRibbonTab(Convert.ToInt32(tabRow("ID")), tabRow("Title").ToString(), Convert.ToInt32(tabRow("Position")), acadTabObject) For Each panelRow As DataRow In RibbonData.Tables("AutoCAD_Ribbon_Panel").Select("AutoCAD_Ribbon_Tab_ID = " + tab.ID.ToString(), "Position") Dim acadPanelObject As New RibbonPanel() Dim acadPanelSourceObject As New RibbonPanelSource() With acadPanelSourceObject .Title = panelRow("Title").ToString() .Tag = panelRow("ID").ToString() .Id = panelRow("ID").ToString() End With acadPanelObject.Source = acadPanelSourceObject Dim panel As New ACADRibbonPanel(Convert.ToInt32(panelRow("ID")), panelRow("Title").ToString(), Convert.ToInt32(panelRow("Position")), tab, acadPanelObject) If Not panelRow.IsNull("Static_Alias") AndAlso panelRow("Static_Alias") = "NiC" Then acadPanelSourceObject.Id = ACAD_RIBBON_NIC_PANEL_ID 'build Row 1 of Nic Panel Dim nicRibbonRow1 As New RibbonRowPanel() nicRibbonRow1.Id = ACAD_RIBBON_NIC_ROW1_ID BuildNiCRibbonPanelRow1(manager, nicRibbonRow1) acadPanelSourceObject.Items.Add(nicRibbonRow1) acadPanelSourceObject.Items.Add(New RibbonRowBreak()) 'build Row 2 of Nic Panel Dim nicRibbonRow2 As New RibbonRowPanel() nicRibbonRow2.Id = ACAD_RIBBON_NIC_ROW2_ID BuildNiCRibbonPanelRow2(manager, nicRibbonRow2) acadPanelSourceObject.Items.Add(nicRibbonRow2) acadPanelSourceObject.Items.Add(New RibbonRowBreak()) 'build Row 3 of Nic Panel Dim nicRibbonRow3 As New RibbonRowPanel() nicRibbonRow3.Id = ACAD_RIBBON_NIC_ROW3_ID BuildNiCRibbonPanelRow3(manager, nicRibbonRow3) acadPanelSourceObject.Items.Add(nicRibbonRow3) acadPanelSourceObject.Items.Add(New RibbonRowBreak()) Else For Each rowRow As DataRow In RibbonData.Tables("AutoCAD_Ribbon_Panel_Row").Select("AutoCAD_Ribbon_Panel_ID = " + panel.ID.ToString(), "Position") Dim acadRowObject As New RibbonRowPanel() acadRowObject.Id = rowRow("ID").ToString() Dim row As New ACADRibbonPanelRow(Convert.ToInt32(rowRow("ID")), rowRow("Name").ToString(), Convert.ToInt32(rowRow("Position")), panel, acadRowObject) For Each itemRow As DataRow In RibbonData.Tables("AutoCAD_Ribbon_Item").Select("AutoCAD_Ribbon_Panel_Row_ID = " + row.ID.ToString(), "Position") Dim itemTypeID As Integer = Convert.ToInt32(itemRow("AutoCAD_Ribbon_Item_Type_ID")) Dim itemID As Integer = itemRow("ID") Dim itemName As String = itemRow("Name") Dim itemGUID As String = Guid.NewGuid().ToString() Dim itemText As String = IIf(itemRow.IsNull("Text"), String.Empty, itemRow("Text")) Dim itemDescription As String = IIf(itemRow.IsNull("Description"), String.Empty, itemRow("Description")) Dim itemPositoin As Integer = Convert.ToInt32(itemRow("Position")) Dim itemShowText As Boolean = itemRow("Show_Text") Dim itemShowImage As Boolean = itemRow("Show_Image") Dim itemSmallImage As Bitmap = Nothing If Not itemRow.IsNull("Small_Image") Then Using ms As New MemoryStream(DirectCast(itemRow("Small_Image"), Byte())) itemSmallImage = New Bitmap(ms) End Using End If Dim itemLargeImage As Bitmap = Nothing If Not itemRow.IsNull("Large_Image") Then Using ms As New MemoryStream(DirectCast(itemRow("Large_Image"), Byte())) itemLargeImage = New Bitmap(ms) End Using End If Dim itemEnabled As Boolean = itemRow("Enabled") Dim itemVisible As Boolean = itemRow("Visible") Dim itemActions As New List(Of ACADRibbonItemAction) For Each actionRow As DataRow In (From n In RibbonData.Tables("AutoCAD_Ribbon_Item_Action") Where n("AutoCAD_Ribbon_Item_ID") = itemID Select n Order By Convert.ToInt32(n("Position"))) Dim actionTypeID As Integer = actionRow("AutoCAD_Ribbon_Item_Action_Type_ID") Select Case actionTypeID Case WF_RIBBON_ACTION_TYPE_ID itemActions.Add(New ACADRibbonItemAction(RibbonObjectType.Item, RibbonItemActionType.RunWorkflow, Convert.ToInt32(actionRow("Position")), actionRow("Action_Data").ToString())) Case ACCESSORY_RIBBON_ACTION_TYPE_ID itemActions.Add(New ACADRibbonItemAction(RibbonObjectType.Item, RibbonItemActionType.AddAccessory, Convert.ToInt32(actionRow("Position")), actionRow("Action_Data").ToString())) Case SHOW_FACTORY_CATEGORY_RIBBON_ACTION_TYPE_ID itemActions.Add(New ACADRibbonItemAction(RibbonObjectType.Item, RibbonItemActionType.ShowFactoryCategory, Convert.ToInt32(actionRow("Position")), actionRow("Action_Data").ToString())) Case Else Throw New NotSupportedException("AutoCAD_Ribbon_Item_Action_Type_ID invalid where AutoCAD_Ribbon_Item_Action_ID = " + actionRow("ID").ToString()) End Select Next Select Case itemTypeID Case 1 'Ribbon Button Dim acadButtonObject As New RibbonButton() acadButtonObject.Name = itemName acadButtonObject.Id = itemGUID acadButtonObject.Tag = itemID acadButtonObject.ShowImage = itemShowImage acadButtonObject.ShowText = itemShowText If itemSmallImage IsNot Nothing Then acadButtonObject.Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(itemSmallImage.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(itemSmallImage.Width, itemSmallImage.Height)) End If If itemLargeImage IsNot Nothing Then acadButtonObject.LargeImage = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(itemLargeImage.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(itemLargeImage.Width, itemLargeImage.Height)) End If If itemShowText AndAlso Not String.IsNullOrEmpty(itemText) Then acadButtonObject.Text = itemText End If If Not String.IsNullOrEmpty(itemDescription) Then Dim buttonToolTip As New RibbonToolTip() buttonToolTip.Title = itemName buttonToolTip.Content = itemDescription If itemLargeImage IsNot Nothing Then buttonToolTip.Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(itemLargeImage.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(itemLargeImage.Width, itemLargeImage.Height)) End If acadButtonObject.ToolTip = buttonToolTip acadButtonObject.Description = itemDescription End If acadButtonObject.CommandHandler = New ACADRibbonCommandHandler(manager) acadRowObject.Items.Add(acadButtonObject) Dim button As New ACADRibbonButton(itemID, itemGUID, itemName, itemTypeID, itemPositoin, itemText, itemDescription, itemShowText, itemShowImage, itemSmallImage, itemLargeImage, itemVisible, itemEnabled, row, acadButtonObject, itemActions) row.Items.Add(button) Case 2 'Ribbon Menu 'Proceed if Ribbon Item has Values If RibbonData.Tables("AutoCAD_Ribbon_Item_Value").Select("AutoCAD_Ribbon_Item_ID = " + itemRow("ID").ToString()).Count() > 0 Then Dim acadMenuObject As New RibbonMenuButton() acadMenuObject.Name = itemName acadMenuObject.Id = itemGUID acadMenuObject.Tag = itemID acadMenuObject.ShowImage = itemShowImage acadMenuObject.ShowText = itemShowText If itemSmallImage IsNot Nothing Then acadMenuObject.Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(itemSmallImage.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(itemSmallImage.Width, itemSmallImage.Height)) End If If itemLargeImage IsNot Nothing Then acadMenuObject.LargeImage = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(itemLargeImage.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(itemLargeImage.Width, itemLargeImage.Height)) End If If itemShowText AndAlso Not String.IsNullOrEmpty(itemText) Then acadMenuObject.Text = itemText End If If Not String.IsNullOrEmpty(itemDescription) Then Dim buttonToolTip As New RibbonToolTip() buttonToolTip.Title = itemName buttonToolTip.Content = itemDescription If itemLargeImage IsNot Nothing Then buttonToolTip.Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(itemLargeImage.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(itemLargeImage.Width, itemLargeImage.Height)) End If acadMenuObject.ToolTip = buttonToolTip acadMenuObject.Description = itemDescription End If Dim menu As New ACADRibbonMenu(itemID, itemGUID, itemName, itemTypeID, itemPositoin, itemText, itemDescription, itemShowText, itemShowImage, itemSmallImage, itemLargeImage, itemVisible, itemEnabled, Nothing, row, acadMenuObject, New List(Of ACADRibbonItemAction)) For Each itemValueRow As DataRow In RibbonData.Tables("AutoCAD_Ribbon_Item_Value").Select("AutoCAD_Ribbon_Item_ID = " + itemRow("ID").ToString(), "Position") Dim itemValueID As Integer = Convert.ToInt32(itemValueRow("ID")) Dim itemValueGUID As String = Guid.NewGuid.ToString() Dim itemValueName As String = itemValueRow("Name").ToString() Dim itemValuePosition As Integer = Convert.ToInt32(itemValueRow("Position")) Dim itemValueText As String = itemValueRow("Item_Value").ToString() Dim itemValueDescription = IIf(itemValueRow.IsNull("Tool_Tip"), Nothing, itemValueRow("Tool_Tip").ToString()) Dim itemValueDefaultSelection As Boolean = itemValueRow("Default_Selection") Dim itemValueImage As Bitmap = Nothing If Not itemValueRow.IsNull("Value_Image") Then Using ms As New MemoryStream(DirectCast(itemValueRow("Value_Image"), Byte())) Dim bmp As New Bitmap(ms) itemValueImage = bmp End Using End If Dim acadMenuItemObject As New RibbonMenuItem() With acadMenuItemObject .Id = itemValueGUID .Tag = itemValueID .Name = itemValueName .Text = itemValueText If itemValueImage IsNot Nothing Then .Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(itemValueImage.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(itemValueImage.Width, itemValueImage.Height)) End If If Not String.IsNullOrEmpty(itemValueDescription) Then .Description = itemValueDescription Dim itemToolTip As New RibbonToolTip() itemToolTip.Title = itemValueText itemToolTip.Content = itemValueDescription .ToolTip = itemToolTip End If .CommandHandler = New ACADRibbonCommandHandler(manager) End With Dim itemValueActions As New List(Of ACADRibbonItemAction) For Each actionRow As DataRow In (From n In RibbonData.Tables("AutoCAD_Ribbon_Item_Value_Action") Where n("AutoCAD_Ribbon_Item_Value_ID") = itemValueID Select n Order By Convert.ToInt32(n("Position"))) Dim actionTypeID As Integer = actionRow("AutoCAD_Ribbon_Item_Action_Type_ID") Select Case actionTypeID Case WF_RIBBON_ACTION_TYPE_ID itemValueActions.Add(New ACADRibbonItemAction(RibbonObjectType.ItemValue, RibbonItemActionType.RunWorkflow, Convert.ToInt32(actionRow("Position")), actionRow("Action_Data").ToString())) Case ACCESSORY_RIBBON_ACTION_TYPE_ID itemValueActions.Add(New ACADRibbonItemAction(RibbonObjectType.ItemValue, RibbonItemActionType.AddAccessory, Convert.ToInt32(actionRow("Position")), actionRow("Action_Data").ToString())) Case SHOW_FACTORY_CATEGORY_RIBBON_ACTION_TYPE_ID itemValueActions.Add(New ACADRibbonItemAction(RibbonObjectType.ItemValue, RibbonItemActionType.ShowFactoryCategory, Convert.ToInt32(actionRow("Position")), actionRow("Action_Data").ToString())) Case Else Throw New NotSupportedException("AutoCAD_Ribbon_Item_Action_Type_ID invalid where AutoCAD_Ribbon_Item_Value_Action_ID = " + actionRow("ID").ToString()) End Select Next Dim menuItem As New ACADRibbonMenuItem(itemValueID, itemValueGUID, itemValueName, itemValuePosition, itemValueText, itemValueDescription, itemValueImage, itemValueDefaultSelection, menu, acadMenuItemObject, itemValueActions) acadMenuObject.Items.Add(acadMenuItemObject) menu.MenuItems.Add(menuItem) Next acadRowObject.Items.Add(acadMenuObject) End If End Select Next panel.Rows.Add(row) acadPanelSourceObject.Items.Add(acadRowObject) acadPanelSourceObject.Items.Add(New RibbonRowBreak()) Next End If acadTabObject.Panels.Add(acadPanelObject) tab.Panels.Add(panel) Next ribbonTabs.Add(tab) Autodesk.Windows.ComponentManager.Ribbon.Tabs.Add(acadTabObject) Next Return manager End Function Private Shared Sub BuildNiCRibbonPanelRow1(Manager As ACADRibbonManager, ACADRowObject As RibbonRowPanel) 'Active Conveyor Menu Dim activeConveyorLabel As New RibbonLabel() activeConveyorLabel.Text = "Conv. #" ACADRowObject.Items.Add(activeConveyorLabel) Dim activeConveyorRibbonCombo As New RibbonCombo() Manager.ActiveConveyorRibbonCombo = activeConveyorRibbonCombo activeConveyorRibbonCombo.Name = "Active Conveyor" activeConveyorRibbonCombo.Id = ACAD_RIBBON_ACTIVECONVEYOR_ITEM_ID activeConveyorRibbonCombo.Tag = ACAD_RIBBON_ACTIVECONVEYOR_ITEM_ID activeConveyorRibbonCombo.ShowImage = False activeConveyorRibbonCombo.IsEditable = False activeConveyorRibbonCombo.Width = 75 If AutoPriceApp.Drawings.ActiveDrawing IsNot Nothing AndAlso AutoPriceApp.Drawings.ActiveDrawing.ActiveEstimate IsNot Nothing Then For Each conveyor As ConveyorModel In AutoPriceApp.Drawings.ActiveDrawing.ActiveEstimate.Conveyors Dim conveyorButton As New RibbonButton() conveyorButton.Id = conveyor.ID conveyorButton.Tag = conveyor.ID conveyorButton.ShowText = True conveyorButton.ShowImage = False conveyorButton.Text = conveyor.Name activeConveyorRibbonCombo.Items.Add(conveyorButton) If AutoPriceApp.Drawings.ActiveDrawing.ActiveEstimate.ActiveConveyor IsNot Nothing AndAlso conveyor.ID = AutoPriceApp.Drawings.ActiveDrawing.ActiveEstimate.ActiveConveyor.ID Then activeConveyorRibbonCombo.Current = conveyorButton End If Next End If AddHandler activeConveyorRibbonCombo.CurrentChanged, AddressOf Manager.OnActiveConveyorRibbonCombo_Changed ACADRowObject.Items.Add(activeConveyorRibbonCombo) 'New Conveyor Button Dim newConveyorRibbonButton As New RibbonButton() newConveyorRibbonButton.Name = "NiCNewConveyorButton" newConveyorRibbonButton.Id = ACAD_RIBBON_NEWCONVEYOR_ITEM_ID newConveyorRibbonButton.Tag = ACAD_RIBBON_NEWCONVEYOR_ITEM_ID newConveyorRibbonButton.ShowImage = True newConveyorRibbonButton.ShowText = False newConveyorRibbonButton.Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(My.Resources.AddConveyor.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(My.Resources.AddConveyor.Width, My.Resources.AddConveyor.Height)) Dim newConveyorToolTip As New RibbonToolTip() newConveyorToolTip.Title = "New Conveyor" newConveyorToolTip.Content = "Add a new Conveyor to the Active Estimate either manually or via a Conveyor Factory." newConveyorRibbonButton.ToolTip = newConveyorToolTip newConveyorRibbonButton.CommandHandler = New ACADRibbonStaticItemCommandHandler(Manager) ACADRowObject.Items.Add(newConveyorRibbonButton) 'Conveyor Prompt Editor Button Dim promptEditorRibbonButton As New RibbonButton() With promptEditorRibbonButton .Name = "NiCConveyorPromptEditorButton" .Id = ACAD_RIBBON_CONVEYORPROMPTEDITOR_ITEM_ID .Tag = ACAD_RIBBON_CONVEYORPROMPTEDITOR_ITEM_ID .ShowImage = True .ShowText = False .Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(My.Resources.EditConveyorPrompts.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(My.Resources.EditConveyorPrompts.Width, My.Resources.EditConveyorPrompts.Height)) End With Dim promptEditorTooTip As New RibbonToolTip() With promptEditorTooTip .Title = "Conveyor Prompt Editor" .Content = "Edit the Prompts of the Active Conveyor, such as Live Load and Nominal Width." End With promptEditorRibbonButton.ToolTip = promptEditorTooTip promptEditorRibbonButton.CommandHandler = New ACADRibbonStaticItemCommandHandler(Manager) ACADRowObject.Items.Add(promptEditorRibbonButton) 'User-Defined Defaults Editor Button Dim defaultsEditorRibbonButton As New RibbonButton() With defaultsEditorRibbonButton .Name = "NiCUserDefinedDefaultsEditorButton" .Id = ACAD_RIBBON_DEFAULTSEDITOR_ITEM_ID .Tag = ACAD_RIBBON_DEFAULTSEDITOR_ITEM_ID .ShowImage = True .ShowText = False .Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(My.Resources.EditUserDefinedDefaults.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(My.Resources.EditUserDefinedDefaults.Width, My.Resources.EditUserDefinedDefaults.Height)) Dim defaultsPromptToolTip As New RibbonToolTip() defaultsPromptToolTip.Title = "User-Defined Defaults Editor" defaultsPromptToolTip.Content = "Edit User-Defined Defaults by Conveyor Type." .ToolTip = defaultsPromptToolTip .CommandHandler = New ACADRibbonStaticItemCommandHandler(Manager) End With ACADRowObject.Items.Add(defaultsEditorRibbonButton) End Sub Private Shared Sub BuildNiCRibbonPanelRow2(Manager As ACADRibbonManager, ACADRowObject As RibbonRowPanel) 'Accessory Editor Button Dim accessoryEditorRibbonButton As New RibbonButton() With accessoryEditorRibbonButton .Name = "NiCAccessoryEditorButton" .Id = ACAD_RIBBON_ACCESSORIESEDITOR_ITEM_ID .Tag = ACAD_RIBBON_ACCESSORIESEDITOR_ITEM_ID .ShowImage = True .ShowText = False .Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(My.Resources.AccessoryEditor.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(My.Resources.AccessoryEditor.Width, My.Resources.AccessoryEditor.Height)) Dim accessoryPromptToolTip As New RibbonToolTip() accessoryPromptToolTip.Title = "Accessory Editor" accessoryPromptToolTip.Content = "Edit Accessories of Active Conveyor." .ToolTip = accessoryPromptToolTip .CommandHandler = New ACADRibbonStaticItemCommandHandler(Manager) End With ACADRowObject.Items.Add(accessoryEditorRibbonButton) 'Guardrail Editor Button Dim guardrailEditorRibbonButton As New RibbonButton() With guardrailEditorRibbonButton .Name = "NiCGuardrailEditorButton" .Id = ACAD_RIBBON_GREDITOR_ITEM_ID .Tag = ACAD_RIBBON_GREDITOR_ITEM_ID .ShowImage = True .ShowText = False .Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(My.Resources.GuardrailEditor.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(My.Resources.GuardrailEditor.Width, My.Resources.GuardrailEditor.Height)) Dim guardrailPromptToolTip As New RibbonToolTip() guardrailPromptToolTip.Title = "Guardrail Editor" guardrailPromptToolTip.Content = "Edit Guardrail of Active Conveyor." .ToolTip = guardrailPromptToolTip .CommandHandler = New ACADRibbonStaticItemCommandHandler(Manager) End With ACADRowObject.Items.Add(guardrailEditorRibbonButton) 'Parts Editor Button Dim partsEditorRibbonButton As New RibbonButton() With partsEditorRibbonButton .Name = "NiCGuardrailEditorButton" .Id = ACAD_RIBBON_PARTSEDITOR_ITEM_ID .Tag = ACAD_RIBBON_PARTSEDITOR_ITEM_ID .ShowImage = True .ShowText = False .Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(My.Resources.PartEditor.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(My.Resources.PartEditor.Width, My.Resources.PartEditor.Height)) Dim partsPromptToolTip As New RibbonToolTip() partsPromptToolTip.Title = "Misc. Part Editor" partsPromptToolTip.Content = "Edit Misc. Parts of Active Conveyor." .ToolTip = partsPromptToolTip .CommandHandler = New ACADRibbonStaticItemCommandHandler(Manager) End With ACADRowObject.Items.Add(partsEditorRibbonButton) 'Specials Editor Button Dim specialsEditorRibbonButton As New RibbonButton() With specialsEditorRibbonButton .Name = "NiCSpecialsEditorButton" .Id = ACAD_RIBBON_SPECIALSEDITOR_ITEM_ID .Tag = ACAD_RIBBON_SPECIALSEDITOR_ITEM_ID .ShowImage = True .ShowText = False .Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(My.Resources.SpecialItemEditor.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(My.Resources.SpecialItemEditor.Width, My.Resources.SpecialItemEditor.Height)) Dim specialsPromptToolTip As New RibbonToolTip() specialsPromptToolTip.Title = "Special Item Editor" specialsPromptToolTip.Content = "Edit Special Items of Active Conveyor." .ToolTip = specialsPromptToolTip .CommandHandler = New ACADRibbonStaticItemCommandHandler(Manager) End With ACADRowObject.Items.Add(specialsEditorRibbonButton) Dim reportViewerRibbonButton As New RibbonButton() With reportViewerRibbonButton .Name = "NiCReportViewerButton" .Id = ACAD_RIBBON_REPORTVIEWER_ITEM_ID .Tag = ACAD_RIBBON_REPORTVIEWER_ITEM_ID .ShowImage = True .ShowText = False .Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(My.Resources.book_reportHS.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(My.Resources.book_reportHS.Width, My.Resources.book_reportHS.Height)) Dim reportViewerPromptToolTip As New RibbonToolTip() reportViewerPromptToolTip.Title = "Report Viewer" reportViewerPromptToolTip.Content = "Open Report Viewer." .ToolTip = reportViewerPromptToolTip .CommandHandler = New ACADRibbonStaticItemCommandHandler(Manager) End With ACADRowObject.Items.Add(reportViewerRibbonButton) End Sub Private Shared Sub BuildNiCRibbonPanelRow3(Manager As ACADRibbonManager, ACADRowObject As RibbonRowPanel) 'Select All Button Dim selectAllRibbonButton As New RibbonButton() With selectAllRibbonButton .Name = "NiCSelectAllButton" .Id = ACAD_RIBBON_SELECTALL_ITEM_ID .Tag = ACAD_RIBBON_SELECTALL_ITEM_ID .ShowText = False .ShowImage = True .Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(My.Resources.quick_select_16x16.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(My.Resources.quick_select_16x16.Width, My.Resources.quick_select_16x16.Height)) Dim selectAllToolTip As New RibbonToolTip() selectAllToolTip.Title = "Select All Conveyor Blocks" selectAllToolTip.Content = "Select all Blocks belonging to selected Conveyor(s)." .ToolTip = selectAllToolTip .CommandHandler = New ACADRibbonStaticItemCommandHandler(Manager) End With ACADRowObject.Items.Add(selectAllRibbonButton) 'Zoom Button Dim zoomRibbonButton As New RibbonButton() With zoomRibbonButton .Name = "NiCZoomButton" .Id = ACAD_RIBBON_ZOOM_ITEM_ID .Tag = ACAD_RIBBON_ZOOM_ITEM_ID .ShowText = False .ShowImage = True .Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(My.Resources.zoom_16x16.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(My.Resources.zoom_16x16.Width, My.Resources.zoom_16x16.Height)) Dim zoomToolTip As New RibbonToolTip() zoomToolTip.Title = "Zoom To Conveyor Extents" zoomToolTip.Content = "Zoom to Active Conveyor extents." .ToolTip = zoomToolTip .CommandHandler = New ACADRibbonStaticItemCommandHandler(Manager) End With ACADRowObject.Items.Add(zoomRibbonButton) 'Isolate Toggle Button Dim isolateRibbonToggleButton As New RibbonToggleButton() Manager.IsolateRibbonToggleButton = isolateRibbonToggleButton With isolateRibbonToggleButton .Name = "NiCIsolateButton" .Id = ACAD_RIBBON_ISOLATE_ITEM_ID .Tag = ACAD_RIBBON_ISOLATE_ITEM_ID .ShowText = False .ShowImage = True .Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(My.Resources.isolateobjects_16x16.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(My.Resources.isolateobjects_16x16.Width, My.Resources.isolateobjects_16x16.Height)) Dim isolateToolTip As New RibbonToolTip() isolateToolTip.Title = "Isolate Selected Conveyor(s)" isolateToolTip.Content = "Isolate Blocks of Selected Covneyor(s)." .ToolTip = isolateToolTip .CommandHandler = New ACADRibbonStaticItemCommandHandler(Manager) End With ACADRowObject.Items.Add(isolateRibbonToggleButton) 'Hide Toggle Button Dim hideRibbonToggleButton As New RibbonToggleButton() Manager.HideRibbonToggleButton = hideRibbonToggleButton With hideRibbonToggleButton .Name = "NiCHideButton" .Id = ACAD_RIBBON_HIDE_ITEM_ID .Tag = ACAD_RIBBON_HIDE_ITEM_ID .ShowText = False .ShowImage = True .Image = System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(My.Resources.hideobjects_16x16.GetHbitmap(), IntPtr.Zero, System.Windows.Int32Rect.Empty, BitmapSizeOptions.FromWidthAndHeight(My.Resources.hideobjects_16x16.Width, My.Resources.hideobjects_16x16.Height)) Dim hideToolTip As New RibbonToolTip() hideToolTip.Title = "Hide Selected Conveyor(s)" hideToolTip.Content = "Hide Blocks of Selected Covneyor(s)." .ToolTip = hideToolTip .CommandHandler = New ACADRibbonStaticItemCommandHandler(Manager) End With ACADRowObject.Items.Add(hideRibbonToggleButton) End Sub End Class
The BuildACADRibbon method is initially invoked. Note that one or more ribbon tabs could be created by this code, depending on the data provided. However, only one ribbon is created currently. If this code has run and my application's ribbon tab is created, the exception occurs when searching. If not, there is no exception. Really I'm just looking for advice about how this exception can be avoided and where I should look for the most likely source of the exception.
Also note that this is a very large plugin (likely hundreds of thousands of lines of code), so providing the full source is just not practical.
Thank you in advance.
Best Regards,
Kevin Brown
Hi Kevin,
Sorry, we will need to reproduce the crash to know what is causing it.
I started with a simple VB.Net project that creates a ribbon tab at runtime and used the search option in AutoCAD 2014.
I still haven't reproduced the crash.
Can you try the attached project and include any specific details that your actual project might be doing to it ?
This will help us investigate this further.
Thank you.
Balaji
Balaji,
Sorry I haven't responded; I was off work for several days. Providing you with a runnable project which reproduces the issue will take time I don't have right now. I will try to get back to you with what you have asked for later this week or next week.
Thank you,
Kevin Brown
