.NET
using com intero to plot layouts
2 REPLIES 2
OsamaElewa
998 Views, 2 Replies
Hi guys I am using com intero  to plot layouts, the code goes well untill reach the plotToFile() line and  the visual studio produces error message as attached in the image and text file.
I tried so many time to change in the string path "//" but the same error and using @ at the begginning also the same, as I think that the string may pruduce this error.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.Interop.Common;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
[assembly: CommandClass(typeof(ZFP_BatchPlotTest_2014.PlottingFunction))]
namespace ZFP_BatchPlotTest_2014
    public class PlottingFunction
        [CommandMethod("ppdf", CommandFlags.Modal)]
        public void PlotPDF()
            AcadApplication app = (AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
            AcadLayouts LayoutsCOLL = app.ActiveDocument.Layouts;
            string strLayOutName;
            //AcadLayout cadLayout;
            //string strModel;
            foreach (AcadLayout cadlayout  in LayoutsCOLL)
                app.ActiveDocument.SetVariable("backgroundplot", 0);
                if (app.ActiveDocument.GetVariable("tilemode") == 1)
                    app.ActiveDocument.SetVariable("tilemode", 0);
                app.ActiveDocument.ModelSpace.Layout.RefreshPlotDeviceInfo();
                strLayOutName = cadlayout.Name;
                app.ActiveDocument.ActiveLayout = cadlayout;
                if (strLayOutName != "Model")
                    app.ActiveDocument.Regen(AcRegenType.acAllViewports);
                    app.ActiveDocument.ActiveLayout.ConfigName = "DWG To PDF.pc3";
                    app.ActiveDocument.ActiveLayout.PlotWithPlotStyles = true;
                    app.ActiveDocument.ActiveLayout.StyleSheet = "FINAL-BK.ctb";
                    app.ActiveDocument.ActiveLayout.CanonicalMediaName = "ISO_A0_(841.00_x_1189.00_MM)";
                    app.ActiveDocument.ActiveLayout.PaperUnits = AcPlotPaperUnits.acMillimeters;
                    app.ActiveDocument.ActiveLayout.PlotRotation = AcPlotRotation.ac90degrees;
                    app.ActiveDocument.ActiveLayout.StandardScale = AcPlotScale.ac1_1;
                    app.ActiveDocument.ActiveLayout.PlotType = AcPlotType.acExtents;
                    app.ActiveDocument.ActiveLayout.CenterPlot = true;
                    //app.ActiveDocument.Plot.DisplayPlotPreview(AcPreviewMode.acFullPreview);
                    app.ActiveDocument.Application.ZoomExtents();
                    //app.ActiveDocument.Plot.PlotToDevice();
                    string strLayoutpath = "L:\\" + strLayOutName + ".pdf";
                    app.ActiveDocument.Plot.PlotToFile(strLayoutpath, app.ActiveDocument.PlotConfigurations);
thanks for your support
2 REPLIES 2
norman.yuan
in reply to: OsamaElewa
Well, there error message is correct, but you attacked wrong data you passed to PlotToFile() method: the second argument expects a AcadPlotConfiguration, while what you passed in is AcadDocument.PlotConfiguations, which is AcadPlotConfigurations (a collection of AcadPlotConfiguration objects).
Norman Yuan
Drive CAD With Code
OsamaElewa
in reply to: norman.yuan
thanks alot for your support
I used the same code but i removed the 'app.ActiveDocument.PlotConfigurations' as its optional and the pdf works now.
thanks alot
”Boost
