.NET
Active Contributor
markgardiner
Message 1 of 10 (966 Views)
using COM API in .net dll
966 Views, 9 Replies
05-23-2005 07:18 PM
I am trying to use the COM API in my .net dll (acad 2005) with C#
I can get the code to work in VB.net but not C#
to get the hosting acad application
'in vba
Public WithEvents m_Acad As AcadApplication
Set m_Acad = AcadApplication
'in vb.net dll
Dim _AcadApp As Autodesk.AutoCAD.Interop.AcadApplication = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
in c#.net dll
//Yet converting the vb.net code to C#
//Build gives error CS0029 cannot convert object to Autodesk.AutoCAD.Interop.AcadApplication
private Autodesk.AutoCAD.Interop.AcadApplication _AcadApp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
I assume the vb.net code is converting the '.net acad object' to the 'com acad object'
I want to avoid using GetActiveObject("AutoCAD.Application.16")
Mark
*Mike Tuersley
Message 2 of 10 (966 Views)
Re: using COM API in .net dll
05-23-2005 09:16 PM in reply to: markgardiner
I'm sure there are lots of opinions and methods, but you should use the
specific application ID which for 2005 is "16.1". Also learn to use the
imports/using statements so you have less typing ;-)
VB.NET
Imports System.Windows.Forms
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Public Function Connect2Acad() As Boolean
'+-- Retrieve or establish reference to AutoCAD [via COM]
' test to see if reference is already established
If IsNothing(cadApp) Then
' no so try accessing existing session
Try
cadApp = Marshal.GetActiveObject("AutoCAD.Application.16.2")
Catch
' existing session not found...fire up Acad
Try
cadApp = CreateObject("AutoCAD.Application.16.2")
Catch AcadEx As Autodesk.AutoCAD.Runtime.Exception
Dim sMsg As String = AcadEx.Message & " from: " & AcadEx.Source
MessageBox.Show(sMsg, "AutoCAD_BasicCalls|Connect2Acad",
MessageBoxButtons.OK, MessageBoxIcon.Error)
Return False
End Try
End Try
End If
' made it here so it worked
Return True
End Function
C#
using System;
using System.Runtime.InteropServices;
using System.Windows.Forms;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
class HitAcad_example
public AcadApplication cadApp;
public AcadDocument cadDoc;
public bool Connect2Acad()
try {
cadApp =(Autodesk.AutoCAD.Interop.AcadApplication)
Marshal.GetActiveObject("AutoCAD.Application.16.1");
} catch {
try {
cadApp =new Autodesk.AutoCAD.Interop.AcadApplication();
cadApp.Visible = true;
} catch (System.Exception AcadEx) {
string sMsg = AcadEx.Message + " from: " + AcadEx.Source;
MessageBoxButtons.OK, MessageBoxIcon.Error);
return false;
return true;
-- Mike
___________________________
Mike Tuersley
the trick is to realize that there is no spoon...
Active Contributor
markgardiner
Message 3 of 10 (966 Views)
05-23-2005 10:08 PM in reply to: markgardiner
ks Mike
I do use 'Imports' or 'using' but sometimes you need the fully qualified name to prevent ambiguity (ie application is in more than one of your imports)
//c# I was missing the (AcadApplication)
Autodesk.AutoCAD.Interop.AcadApplication _AcadApp = (AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
I didn't want to use GetActiveObject is this can return any running instance of acad and not necessarly the one my .net dll is loaded into.
Mark
*Mike Tuersley
Message 4 of 10 (966 Views)
05-24-2005 08:19 AM in reply to: markgardiner
Haven't had that problem
Well you can't create a new instance from a dll already running in AutoCAD!
Sorry I misread that portion of your post. You either need to use
GetActiveObject or a bit of managed code to get the host something like:
Imports AcadApp = Autodesk.AutoCAD.ApplicationServices.Application
Public Shared m_CoAcadApp As Autodesk.AutoCAD.Interop.AcadApplication =
CType(AcadApp.AcadApplication, AcadApplication)
-- Mike
Mike Tuersley
*Paul Richardson
Message 5 of 10 (966 Views)
05-24-2005 08:26 AM in reply to: markgardiner
>name to prevent >ambiguity (ie application is in more than one of your
>imports)
Isn't avoiding this the idea behind Namespaces, while enjoying short
typing with using directives? Mike help??
wrote in message news:4854118@discussion.autodesk.com...
ks Mike
imports)
Mark
*Mike Tuersley
Message 6 of 10 (966 Views)
05-24-2005 08:54 AM in reply to: markgardiner
Yes, and actually depending upon how you write your code there are a few
places where you still need to type it all out but I've only ever run into
it with the managed API [Graphics], never with COM.Try this to see it:
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.GraphicsInterface
Then try declaring: Dim oVport As New Viewport
You'll get the ambiguitity error. In my case here, I really wasn't using
GraphicsInterface so I removed it =)
-- Mike
Mike Tuersley
*Paul Richardson
Message 7 of 10 (966 Views)
05-24-2005 09:28 AM in reply to: markgardiner
Thanks..
"Mike Tuersley" wrote in message
news:4854721@discussion.autodesk.com...
-- Mike
Mike Tuersley
New Member
palaniselvam
Message 8 of 10 (966 Views)
12-07-2009 06:31 AM in reply to: markgardiner
I have installed Architecture 2009 standalone version on my local machine. I am calling autocad document from Windows C# and getting the following error. Can you help me to fix this error?
"Retrieving the COM class factory for component with CLSID {28B7AA99-C0F9-4C47-995E-8A8D729603A1} failed due to the following error: 80080005."
My Code is:
try
acadapp = (AcadApplication)Marshal.GetActiveObject("AutoCAD.Application");
catch
try
Type acType = Type.GetTypeFromProgID("AutoCAD.Application");
acadapp = (AcadApplication)Activator.CreateInstance(acType, true);
catch (System.Exception ex)
If I use the following code then application is throwing an error as " it is not able to find out form(class) name"
acadapp = (Autodesk.AutoCAD.Interop.AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
*Tony Tanzillo
Message 9 of 10 (966 Views)
12-07-2009 10:27 AM in reply to: markgardiner
If the error happens when AutoCAD is running, then try
"AutoCAD.Application.17.2" rather than just "AutoCAD.Application".
To create a new instance of AutoCAD you can just use:
AcadApplication app = new AcadApplication();
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6300407@discussion.autodesk.com...
80080005."
My Code is:
try
acadapp =
catch
try
Type acType =
acadapp =
acadapp =
New Member
palaniselvam
Message 10 of 10 (966 Views)
12-08-2009 02:10 AM in reply to: markgardiner
Thanks Tony. I opened AutoCAD 2009 through program menu and tried with the following code. It is working. My concern is like why should I run AutoCAD s/w first and run this program. This is the case through my C# program I need to kickoff autocad software and use the following code to create the instance for ACAD document. How Can I kickoff AutoCAD s/w?
AndI have some autocad document(linked with oracle db(uid/pwd). Through C#, I need to pass UID/PWD to open the Autocad document. Is there any way we can do that?
try
acadapp =
catch
try
Type acType =
acadapp =
How can I pass user id / password to autocad document. I have seen the following code accepts only pwd:
acadapp.Documents.Open(dtFileList.Rows[intRowCount]["FileName"].ToString(), false, pwd);
Here If I pass pwd as string then autocad document should not prompt to enter UID/PWD. Is it possible?
Thanks and Regards,
Palani. Edited by: palaniselvam on Dec 8, 2009 10:17 AM
