.NET
Member
cfiene
Message 1 of 4 (295 Views)
user forms
295 Views, 3 Replies
10-10-2012 10:36 AM
Intermediate programmer here . .
I developed a program in VBA that used a form to allow users to create new dwg files based on selected criteria . . . . the vba program would then create and open the new dwg file and in the case of sheet files, it would populate title block attributes as well.
In vba, the forms focus was carried to the new file so the application would fill in the attributes, etc. as described above,
However in vb.net, I have not been able to get the form to recognize the new file. The program creates and opens the file, however the forms focus is still on the initial file so any actions to be applied to the new file are not carried out.
Any suggestions?
Thanks in advance.
Board Manager
StephenPreston
Message 2 of 4 (263 Views)
Re: user forms
10-11-2012 12:36 AM in reply to: cfiene
So you've opened a DWG in a new document and want that to become the active document? Have you tried Application.DocumentManager.MDIActiveDocument = XXX, whwre XXX is the new document you opened/created? If that doesn't help, then a code sample would help demonstrate what you're trying to do.
Cheers,
Stephen Preston
Autodesk Developer Network
Member
cfiene
Message 3 of 4 (245 Views)
Re: user forms
10-11-2012 07:37 AM in reply to: StephenPreston
Yes, that is correct. I will try your suggestion and let yuou know.
Thanks very much!
Member
cfiene
Message 4 of 4 (155 Views)
Re: user forms
01-03-2013 04:59 AM in reply to: StephenPreston
Hi Stephen,
I did not have a chance to look at my code for quite some time . . . some project deadlines etc . .
I tried your suggestion and it did not work. The error was indicating that the file name could not be a string variable. I did a little more resarch and foud that the follwing code worked:
Autodesk.AutoCAD.ApplicationServices.
Application.DocumentManager.Open(sNewFile, False)
Where sNewFile is the file I created from the applicaiton.
Hope this helps and thanks once again for your response.
Chris
