.NET
Use AutoCAD2015 API with VStudio201​0
1 REPLY 1
395 Views, 1 Reply
SDK AutoCAD2015 samples are in VStudio2012.
It is possible use the VStudio2010 to develop addin for the AutoCAD2015? Or is mandatory the VStudio2012?
I think AutoCAD 2013/2014 is related with VStudio2010. If I develop addins with AutoCAD2013/2014 SDK and VStudio2010, they will be compatible with AutoCAD2015?
Thanks & Regards,
Rui
1 REPLY 1
_gile
AutoCAD 2005 was the first AutoCAD version supporting .NET technology.
Since AutoCAD 2006 a .NET Framework Runtime version is automatically installed with AutoCAD.
Each Visual Studio version is related to a .NET Framework version.
Visual Studio 2008 and later versions allow to target previous versions of .NET Framwork since 2002.
AutoCAD    .NET framework Runtime   Visual Studio
2005           1.0 (not installed)              2002
2006           1.1                                    2003
2007           2.0                                    2005 (or later)
2008           2.0                                    2005 (or later)
2009           3.0                                    2008 (or later)
2010           3.5                                    2008 (or later)
2011           3.5                                    2008 (or later)
2012           4.0  (3.5 supported)          2010 (or later)
2013           4.0                                    2010 (or later)
2014           4.0                                    2010 (or later)
2015           4.5                                    2012 (or later)
So, as AutoCAD 2015 targets the .NET Framework 4.5, Visual Studio 2012 is mandatory to use the AutoCAD 2015 .NET SDK. But, most of the time, applications built against .NET Framework 4.0 and AutoCAD 2013 SDK may work with AutoCAD 2015 without any changes.
Gilles Chanteau
GileCAD
GitHub
”Boost
