.NET
Urgent: How to Extract ole file names from dwg file
1 REPLY 1
aslam
290 Views, 1 Reply
Dear All,
There is a dwg file on disk which have some ole objects. I need to extract ole file names and paths from this Dwg file through programming. Has anybody an idea?
Thanks....
1 REPLY 1
lleandro
in reply to: aslam
Autodesk.AutoCAD.DatabaseServices.ObjectId imgDictID = RasterImageDef.GetImageDictionary(db);
DBDictionary imgDict;
if (imgDictID.OldId == 0)
imgDictID = RasterImageDef.CreateImageDictionary(db);
// test the image dictionary and the raster before going further
Autodesk.AutoCAD.DatabaseServices.ObjectId TestImgDictID = RasterImageDef.GetImageDictionary(db);
imgDict = (DBDictionary)trans.GetObject(imgDictID, OpenMode.ForRead, false);
foreach (DBDictionaryEntry def2 in imgDict)
RasterImageDef rasterDef = (RasterImageDef)trans.GetObject(def2.Value, OpenMode.ForRead, false);
string jpegFilename = rasterDef.SourceFileName;
”Boost
