.NET
Updating of User Variable ( Parameters ) with VB.Net
1 REPLY 1
murali.koppu
663 Views, 1 Reply
Dear All,
This is K.Murali kumar ( Programmer )
I want to Access User Variables which are created in Parameter Dialog Box through VB.Net Program.
Please any one help me.
How to Access the User variables.
Secondly i want to Update the User Variables with VB.Net Program.
I able to access the Dimensional Constraints with the below code
' Filling the Dimensional Constraints in a ListBox on from
Tools.ZoomExtents()
Dim acTypValAr(0) As TypedValue
acTypValAr.SetValue(New TypedValue(DxfCode.LayerName, "*ADSK_CONSTRAINTS*"), 0)
Dim Flt As New Autodesk.AutoCAD.EditorInput.SelectionFilter(acTypValAr)
Dim Sset As Autodesk.AutoCAD.EditorInput.PromptSelectionResult = Tools.Editor.SelectAll(Flt)
ListBox1.Items.Clear()
Dim oID As ObjectId
If Sset.Value IsNot Nothing Then
For i As Integer = 0 To Sset.Value.Count - 1
oID = Sset.Value.Item(i).ObjectId
Dim Ent As Entity = Tools.GetEntity(oID)
Dim EntType As String = UCase(Ent.ToString)
If EntType = UCase("Autodesk.AutoCAD.DatabaseServices.DiametricDimension") Then
Dim DD As DiametricDimension = Ent
Dim DimVal As String = DD.DimensionText
ListBox1.Items.Add(DimVal)
ElseIf EntType = UCase("Autodesk.AutoCAD.DatabaseServices.LineAngularDimension2") Then
Dim DD As LineAngularDimension2 = Ent
ElseIf EntType = UCase("Autodesk.AutoCAD.DatabaseServices.AlignedDimension") Then
Dim DD As AlignedDimension = Ent
Next
ListBox1.Sorted = True
1 REPLY 1
in reply to: murali.koppu
There's no managed API for accessing contstraints or parameters.
There is a native API, but I haven't had a chance to explore it, so I can't
tell you if it allows you to do what you want, but I will dare to say that
not providing a high-level API to access variables used in constraint
parameters was an incredibly stupid decision, not to mention grossly
neglegent.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6293549@discussion.autodesk.com...
Dear All,
Tools.ZoomExtents()
0)
Dim oID As ObjectId
Then
ElseIf EntType =
Then
Next
”Boost
