.NET
Updating drawings without bringing up Autocad
3 REPLIES 3
steve.pierog
494 Views, 3 Replies
Is there a way to Update drawings such as changing layers, etc without creating a dll and a commanmethod?
I would like to write a VS app that would make changes directly to the drawing and not have to use the commandmethod approach.
3 REPLIES 3
arcticad
in reply to: steve.pierog
You would have to pay for RealDWG or use openDWG
http://www.opendwg.org/
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=770257
(defun botsbuildbots() (botsbuildbots))
kcimos
in reply to: arcticad
I have no experience with this at all, but I want to get into it, & I have found this swamp article with intersting info about ObjectDBX
http://www.theswamp.org/index.php?topic=39365.0
arcticad
When you are linking into AutoCAD from an external program you would use ObjectDBX to access the properties of the object. However you still have to have a copy of AutoCAD running.
”Boost
