.NET
Update Plotter Device List
4 REPLIES 4
SENL1362
682 Views, 4 Replies
Recently i discovered that my Plotter Device List is not beeing refreshed after a AutoCAD profile change using:
PlotConfigManager.RefreshList(RefreshCode.All);
Neither could i find a Refresh function in the UserConfigurationManager:
Application.UserConfigurationManager.xxREFRESHxx
Run the following code twice, before and after a profile change, and for each profile a different  Plotter Configuration Search path.
Notice the differences in the PC3 contents.
       [CommandMethod("LPD")]
        public void ListPlotDevices()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            PlotSettingsValidator plotSettingsValidator = PlotSettingsValidator.Current;
            //The Device list generated by the plotSettingsValidator is not refreshed
            //  after a AutoCAD Profile change -- within the same autoCAD session
            var pc3ListByPSV = plotSettingsValidator.
                                                   GetPlotDeviceList().
                                                   Cast<string>().
                                                   Where(pd => Regex.IsMatch(pd,"PC3$",RegexOptions.IgnoreCase)).
                                                   ToList();
            ed.WriteMessage("\nPlot Device List by PlotSettings Validator:");
            pc3ListByPSV.ForEach(pd => ed.WriteMessage("\n{0}", pd));
            dynamic acadPreferences = Application.Preferences;
            dynamic acadPrefsFiles = acadPreferences.Files;
            string acadprinterConfigPath = acadPrefsFiles.PrinterConfigPath;
            ed.WriteMessage("\n\nPrinter Config Path:{0}", acadprinterConfigPath);
            var pc3ListByDir = Directory.EnumerateFiles(acadprinterConfigPath, "*.pc3").Select(n => Path.GetFileName(n)).ToList();
            ed.WriteMessage("\nPlot Device List(PC3) by Directory search:");
            pc3ListByDir.ForEach(pd => ed.WriteMessage("\n{0}", pd));
Any tips are welcome.
4 REPLIES 4
Balaji_Ram
in reply to: SENL1362
Hi Anton,
Sorry for the delay.
Can you please try this code snippet to refresh the list ?
using (Transaction Tx = doc.Database.TransactionManager.StartTransaction())
    LayoutManager layoutMgr = LayoutManager.Current;
    Layout layout = Tx.GetObject(layoutMgr.GetLayoutId(layoutMgr.CurrentLayout), OpenMode.ForWrite) as Layout;
    plotSettingsValidator.RefreshLists(layout);
    Tx.Commit();
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
SENL1362
in reply to: Balaji_Ram
Hello Balaji_Ram ,
Thank you for you're time, this indeed solved the issue.
But does that mean that
is worthless?
Balaji_Ram
Sorry, I am not aware of the reason why the other PlotConfigManager.RefreshList would not work.
I will let you know if I find anything related to this.
Balaji
Balaji
SENL1362
No hurry, just curios to the reason why.
I'l Appreciate you're support.
”Boost
