.NET
Update object
6 REPLIES 6
sardanapalo
446 Views, 6 Replies
Update object
What would it be the ARX.NET equivalent of This VBA line of code
circle.update
for updating a single grapical object on the model space
6 REPLIES 6
in reply to: sardanapalo
.NET has no equivalent to Update() at the entity level.
The way you do things in .NET makes it unnecessary at
best, and wasteful at worst.
When you modify an object in .NET, you do it in a
Transaction. The Transaction will cause all modified
entities to update when the transaction is committed.
If you are new to .NET, I recommend going through
all of the introductory materials that are available from
Autodesk's website, and elsewhere.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6348340@discussion.autodesk.com...
circle.update
sardanapalo
My fault for not being more specific.
The problem is that the entity I want to update has not been directly modified during the transaction (I guess). I'm talking of associative dimensions linked to a modified object. I have a modal dialog that controls the shape of a polyline; If I do UpdateScreen after some changes I get the polyline updated but not the associative dimensions. It's only upon dialog closing that the dimensions get updated. I want to avoid this behavior
Are you using a transaction, and if so, when it is being committed?
wrote in message news:6350811@discussion.autodesk.com...
sardanapalo
Yes, I am, and it is committed before I do UpdateScreen, that's why I get the polyline correctly updated from the dialog.
The problem you note has nothing to do with the form.
You can reproduce this bug with nothing more than
a simple command-line based command that modifies
an object associated with a dimension. Even in that
case, after ending the transaction the dimension does
not update. It doesn't update until the command handler
exits.
It's a bug as far as I'm concerned.
wrote in message news:6350863@discussion.autodesk.com...
sardanapalo
I see, thanks anyway
”Boost
