.NET
Valued Contributor
0 Kudos
Post 1 of 6
unwanted zoom in loop command
219 Views, 5 Replies
02-12-2013 06:02 AM
I have a portion of my routine below. Basically I need the user to continue to loop through the command. They are picking Circles or blocks in the drawing and I get the insertion point, then insert a new block. However, whenever they try and use a transparent zoom or pan to move around the drawing when the promptentityresult is hit, it zooms back to the original location. How do I stop it from doing that? Any help or direction is much appreciated. Here is a code....
CommandMethod("getpnt", CommandFlags.Session)> _
  Sub findpnt()
  Dim cnt AsInteger = 0
  Dim NEWPNT AsPoint3d = GetInsPoint()
  While cnt < 3
            NEWPNT = GetInsPoint()
' other code is inserted here...
            cnt = cnt + 1
  EndWhile
  EndSub
Public Function GetInsPoint()
Dim inspnt AsPoint3d
Dim acdoced AsDocument = Application.DocumentManager.MdiActiveDocument
Dim myed AsEditor = acdoced.Editor
Dim db AsDatabase = HostApplicationServices.WorkingDatabase
Using mytrans2 AsTransaction = db.TransactionManager.StartTransaction()
Dim myPEO AsNewPromptEntityOptions(vbLf & "Select Circle or Block: ")
            myPEO.SetRejectMessage(
"You must select a Circle or Block.")
            myPEO.AddAllowedClass(
GetType(Circle), True)
GetType(BlockReference), True)
            myPEO.AllowNone =
False
Dim symbolent AsPromptEntityResult = myed.GetEntity(myPEO)
If symbolent.Status = PromptStatus.OK Then
Dim Objid AsObjectId = symbolent.ObjectId
Dim ent AsEntity = CType(mytrans2.GetObject(Objid, OpenMode.ForRead), Entity)
Dim enttype1 AsString = ent.GetType().ToString
Dim enttype AsString = Objid.ObjectClass.DxfName
SelectCase enttype
Case"CIRCLE"
Dim circleobj AsCircle = mytrans2.GetObject(Objid, OpenMode.ForRead)
                        inspnt = circleobj.Center
Case"INSERT"
Dim blockent AsBlockReference = mytrans2.GetObject(Objid, OpenMode.ForRead)
inspnt = blockent.Position
EndSelect
EndIf
EndUsing
Return inspnt
EndFunction
This is an interesting issue I have not noticed before and did not know current view seems associated with a new started transaction.
The reason AutoCAD always restore back to original view after each pick is that you did not commit the Transaction in the GetInsPoint() function.
As rule of thumb, one should always EXPLICITLY complete the transaction, either commit it, or abort it. If a transaction is wrapped in Using ... End Using, when End Using is reached, if the transaction has not been commited, it will be aborted before being disposed, which may not be what you want, as your code behaves.
So, you need to add mytrans2.Commit() right before End Using.
216 Kudos
Post 2 of 6
Re: unwanted zoom in loop command
02-12-2013 08:12 AM in reply to: cjacobi
Valued Contributor
0 Kudos
Post 3 of 6
02-12-2013 08:15 AM in reply to: norman.yuan
thanks!  I will make that change. maybe that will resolve the issue.
216 Kudos
Post 4 of 6
02-12-2013 08:18 AM in reply to: cjacobi
I forgot to mention: I actually tried your code.
Not "maybe". It IS because of the transaction not being commited.
Valued Contributor
0 Kudos
Post 5 of 6
02-12-2013 08:25 AM in reply to: cjacobi
That was it.....found a couple other locations that I did not commit my transactions. Still learning .NET as you can tell.
Once I got those cleared up, the routine is working like it should and is not zooming automatically!
Thanks so much for your help.
Moderator
277 Kudos
Post 6 of 6
02-12-2013 12:26 PM in reply to: norman.yuan
Excellent, Norman!
I thought that this is due to CommandFlags.Session, but you're absolutely right.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
