.NET
Unselectable AutoCad Entity
2 REPLIES 2
soumen.r
1030 Views, 2 Replies
I want to make some AutoCad entities unselectable. Is it possible, by any command or programming?
Soumen
SRoy
2 REPLIES 2
Alfred.NESWADBA
in reply to: soumen.r
you can create an eventhandler that reacts for selection-changes (and if your specific object is selected your code cancels the selection). But in this case your app has to be loaded and running.
I would not know a solution to make an entity not selectable without having your app loaded (for dotNET based apps). Sorry.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Preventing AutoCAD objects from being selected using .NET
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
